Meraki MX and Cisco ATA
PG85
Beginner
Beginner
I'm having an issue where no Cisco ATA192 (I've tried 6 of them) is automatically getting an IP address. The Meraki MX84 is providing DHCP and is on the newist firmware 18.107 (there was a DHCP issue with the previous version). It is providing IP's because no other device is having an issue including new Cisco CP8851 that are being installed. If I take the ATA to another location that is using a MX64 it works just fine. Also if I put a static IP in the ATA it still doesn't work. Its odd because if I do a packet capture from the MX84 for the ATA there is nothing in it and the event log for it just says DHCP problem extra: no_offers_received, vap: 0, vlan: 0.
The enviroment is a single LAN there is no VLAN's set up. The ATA192 is preconfigured from RingCentral. I do have the event log from the ATA if that will help.
PG85
Beginner
Beginner
Finally fixed it. Found the download for the ATA firmware and now it works.
PG85
Beginner
Beginner
Recognize Your Peers
