Message Waiting Indicator (MWI)
nasser2002_2005
Hi Everyone,
After reboot the Unity connection The users report that no messages in their voicemail but MWI light is ON.
I have reset the MWI from Unity Connection . also I plug out and plugin.
Any idea?
nasser2002_2005
The issue resolved.
 the SUB was taking the primary role and the PUB had the notifier off. We changed the PUB to be the one taking the calls and test and we found that the MWI was working fine.Sub was not having ports registered, I reset the port group and also restarted the conversation manager, the issue was fixed after this.
Thank you.
Ratheesh Kumar
Hi there
Which version of CUC are you running and whats the integration SIP or SCCP? Is this affecting all the users or some ?
Could you Run the Check Telephony Configuration test and see you are getting any errors, also try restaring the Connection Notifier service
The below are a couple of links for troubleshooting the issue.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/troubleshooting/guide/10xcuctsgx/10xcuctsg050.html#39867
https://supportforums.cisco.com/t5/collaboration-voice-and-video/message-waiting-indicator-mwi-is-not-working-on-cisco-unity/ta-p/3136630
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
nasser2002_2005
The issue resolved.
Thank you.
