MGCP and H323 Protocols on Same Gateway
csco11063007
Dear Folks,
Can we enable both MGCP and H323 on same gateway.meaning that MGCP will use for PRi and H323 for analog Ports.
Also Please give any stable IOS for MGCP.
Thanks in Advance
Jaime Valencia
yes, you can use both protocols on the same GW, this has been asked twice over the past 2 weeks, please try searching on previous posts
javalenc
if this helps, please rate
java
Jaime Valencia
javalenc
java
Thanks.I will do it in future
Possible/Advisable to share the same circuit between MGCP/H323 protocols on the same gateway?
Not possible, you need to choose one and stick to it per circuit.
ie 0/0/0 MGCP
0/0/1 H323
java
