MGCP fax resent
alex goshtaei
Hi All,
I've setup MGCP fax in gateway with CUCM 7.1 and Exchange 2007 as fax server for incoming faxes. everything works as expected, except sometime end users receive multiple faxes from the same source. it seems gateway doesn't send disconnect or bye message to the outside fax machine.
any suggestion would be very appreciated.
Alex
steve7388
Hi:
Do you fix this problem. can you share your GW mgcp configure ?
I have the same problem.
