MGCP Gateway outbound call issue
aneesshafiq123
Dear Team,
I am not able to dial when I hook off the receiver as soon as I press 9 and then I press digit after 0, I heard greeting message that call is not completed as dialed.
But at the same time when I complete dialed my number with 9 and the press the call button it works successfully.
I knew that when ever i press digit it passes the digit to gateway but what I feel the problem is when I pressed 9 then 0 then 5 .. the call is immediately start dialing and then number is not found.
How can I fix the issue that gateway have to wait for complete number before sending to PSTN
gmgarrian
Level 4
Level 4
 Called Party Number i = 0x80, '905'
Since the PRI is seeing just three digits it must be matching a route pattern and routing the call without waiting for the interdigit timeout.  I would check your route patterns for one that matches 905 and see how that is confitured.  You can also run this through the dialed number analyzer to see the call flow.
Jaime Valencia
What is the call flow? who is on the other side of that GW?
java
if this helps, please rate
gmgarrian
Level 4
Level 4
