10-07-2015 01:37 AM - edited 03-17-2019 04:30 AM
What exactly do the "Enable Status Poll" & "Unattended Port" options mean on an MGCP PRI port?
The CCMAdmin docs don't seem to mention them, and google doesn't seem to be helping either :-/
GTG
10-07-2015 02:02 AM
Hi Gordon.
Enable status poll is an option to put b channels of a circuit in maintenance mode and has the same effect of the following command given on a VG's serial interface:
isdn service b_channel 0-30 state 1 (1 is maintenance value)
For unattended port, it indicate to cucm that calls for this line will be forwarded to an application server such as voice mail.
https://books.google.it/books?id=2pzLsAF6MwkC&pg=PA132&dq=%22Unattended+Port%22&hl=it&sa=X&ved=0CCkQ6AEwAGoVChMIuN61hv2vyAIVAlgUCh0mbwd6#v=onepage&q=unattended&f=false
Cheers
Carlo
10-07-2015 02:39 AM
Hmm. The "Unattended Port" explanation is quite vague :-/ I'll leave it alone...
Are you aware of any pitfalls of leaving the Enable Status Poll flag set?
GTG
10-07-2015 02:52 AM
Because it put b channels in maintenance mode, it would make your circuit unavailable.
So I would leave that option unchecked
Carlo
