12-02-2013 10:41 AM - edited 03-16-2019 08:40 PM
Hello all,
Here is the scenario:
Site A - CUCM Pub/Sub / MGCP gateway
Site B - CUCM Sub / MGCP gateway
Site C - CUCM Sub / MGCP gateway
The sites are using the standard local route group with TEHO per location. Site A (HQ) has s discount carrier for LD, and therefore it would be cost effective to backhaul the LD from Site B and Site C to the Site A PRIs.
Can this be accomplished while using Standard Local Route Groups or is it necessary to go back to site specific routing?
JN
Solved! Go to Solution.
12-02-2013 12:00 PM
In CUCM 9 and older you can only have a single local route group per device pool (this changed on version 10), so you will either have to define the Local or LD RG as your Local Route group and then use standard route patterns/route lists/route group configuration for the other calls, so at site B you would have (assuming local route group is local trunks):
Local Pattern --> Standard Local RL
911 pattern --> Standard Local RL
LD pattern --> SiteB LD RL
Intl pattern --> SiteB LD RL
etc
HTH,
Chris
12-02-2013 12:00 PM
etc
HTH,
Chris
