01-25-2013 02:11 AM - edited 03-16-2019 03:22 PM
Hello guys,
We are facing issues with MGCP gateway registration. Earlier the MGCP gateway was properly registered with the call manager. Recently we had an activity wherein we had to change the domain name of the MGCP gateway router. So we changed the domain name of the router and made similar changes to the MGCP gateway configuration in the CIsco Call Manager. But after making the configuration changes we noticed that the status of the gateway in CUCM was show as "unknown unknown".
But at the same time when we checked in the MGCP gateway with "show ccm-manager", we noticed that the call manager server was successfully registered with the gateway router. We are also able to ping the call manager ip from the gateway router.
Similar we also found that the calls were getting connected properly. The CUCM version is 7.1.5
Has anyone faced similar issue before....please guide us.
Best Regards.
Solved! Go to Solution.
01-25-2013 02:14 AM
We have seen this issue may times.
Restart "RIS Data Collector" and "Database Layer Monitor service" on the call manager server
Ronak Patel
Rate Helpful posts.
01-25-2013 02:14 AM
Ronak Patel
Rate Helpful posts.
01-25-2013 05:20 AM
Thanks for quick reply.
But what could be the reason for this issue?
Best Regards.
01-27-2013 09:46 PM
It depends on case to case base. May be some bug which is not identifed yet.
Ronak Patel
11-23-2013 03:21 AM
I'm having the same issue with an MGCP gateway, its registration status is unknown on cucm but a show ccm-manager on the gateway shows its registered.
If i do a restart of "RIS Data Collector" and "Database Layer Monitor service" on the pub and subs will it cause a service outage at all?
11-23-2013 07:15 AM
both the services are basically for monitoring purpose and collecting real time information for device .
what is the Call manager version u are using? can u share show version and show diag of router?
also, share show ccm-manager and show isdn status.
regds,
aman
