06-18-2010 03:35 AM - edited 03-15-2019 11:18 PM
I have a problem to migrate CUCM 4.1 (3) to CUCM 7.1 (3b) using a DMA version 7.1.3.
When I run DMA, I have the error message in attachment.
Do you think that’s problem of version? it’s correct to migrate directly CUCM 4.1(3) to 7.1(3) or I must to use a version intermediate?
Just for your information, I uninstall the integration with AD before running the DMA, it can provide a problem?
Thanks a lot,
Best Regards,
Omar
06-18-2010 03:42 AM
Your output says you have a succesful output with warnings. This means your DMA file will import, but some things may be missing or broken.
Click the 'Warnings Log' button, and search the logs for 'warning'. If you aren't sure what the warnings mean or how to address them, post it back here.
Aaron
Please rate helpful posts...
06-18-2010 04:05 AM
Hi Aaron,
Thanks too much for your quick answer;
Please, I send you the file Warning in attachement, if you can help me.
I want to know if I run the installation of CUCM 7.1 using this DMA Export file, what conseques would be generated in my New system?
Thanks again,
Best Regards,
Omar
06-18-2010 05:15 AM
I see an LDAP error, presumably due to you having removed LDAP.
Also see errors like this:
Table: CallingSearchSpace 2010-06-17 19:15:16
Row: 24 SQL error: -746(35133)
Error executing "update CallingSearchSpace set Name='SOPHAL_Internat_IPMA_CSS_M_E' where pkid='d2c50042-0008-4804-bac8-29deb4fc1fa5'": [Informix][Informix ODBC Driver][Informix]Unspecified System Error = -746. sqlerrm(35133)
pkid d2c50042-0008-4804-bac8-29deb4fc1fa5 NOT MODIFIABLE
Name SOPHAL_Internat_IPMA_CSS_M_E
Description CDG Manager accès àl'international
DialPlanWizardGenID
Clause Generated_IPMA_Managers:logue:Interne:Interdirecteur:VMPilotNumberPT:VMPilotNumber2 NOT MODIFIABLE
resetToggle false
tkReset 2
tkPartitionUsage 99 NOT MODIFIABLE
I suspect these are cuased by the 'description' field having special characters in it. Later, other elements also fail:
Row: 74 SQL error: -746(35133)
Error executing "update CallingSearchSpaceMember set fkRoutePartition='6223602d-61df-4aad-a497-a451e0afb8bd' where pkid='4ff5ea2f-b2b5-4463-b7ba-2366a688829e'": [Informix][Informix ODBC Driver][Informix]Unspecified System Error = -746. sqlerrm(35133)
pkid 4ff5ea2f-b2b5-4463-b7ba-2366a688829e NOT MODIFIABLE
fkCallingSearchSpace d2c50042-0008-4804-bac8-29deb4fc1fa5 NOT MODIFIABLE
fkRoutePartition 6223602d-61df-4aad-a497-a451e0afb8bd
SortOrder 4
I believe this is because the earlier CSS was not imported to Informix, so the PKID (d2c50042-0008-4804-bac8-29deb4fc1fa5) is not a valid reference.
What I would do is change the single CSS above to have a simple description, and then re-run DMA. If there is no error logged for this on this attempt, I would then correct the description fields on the other CSSs.
Aaron
Please rate helpful posts and mark answered questions that you've got a satisfactory response from to help identify useful content in the forums...
https://supportforums.cisco.com/docs/DOC-6212
06-18-2010 06:47 AM
You have used special character.
Remove all äöü ' ^and so on and rerun the DMA.
Chers Roland
06-18-2010 08:48 AM
Hi All,
thanks too much for your help and answer.
I change the Description of CSSs with the simple description, and the no error message about CSS display. But I have always the 2 others messages error:
06/18/2010 16:46:52
Warning: LDAP Operation Failed
ErrorCode = 32
ErrorMessage = No such object
ErrorName = LDAP_NO_SUCH_OBJECT
ErrorText = The server cannot find an object specified in the request
LDAP_HOST = ccmpublisher
LDAP_PORT = 8404
LDAP_DN = cn=Directory Manager, o=cisco.com
LDAP_PWD = *****
Condition: LDAP Search failed
Solution: Please note the LDAP error
I want to inform you that I remove the integration with AD before running the DMA, it’s not recommended to do this action?
Row: 356 SQL error: -746(35288)
Error executing "update DeviceNumPlanMap set fkDevice='c29fa4f3-9d79-4c26-997d-991c939c1ff4' where pkid='5eaf2ac1-dae7-42d3-ae0a-2d7dbe2cda9c'": [Informix][Informix ODBC Driver][Informix]Unspecified System Error = -746. sqlerrm(35288)
pkid 5eaf2ac1-dae7-42d3-ae0a-2d7dbe2cda9c NOT MODIFIABLE
fkDevice c29fa4f3-9d79-4c26-997d-991c939c1ff4
NumPlanIndex 1
Label FILALI JAOUHARI Abdeslam BLOCKED
fkNumPlan 2dd6c08e-1f09-450d-8b0e-295fc38a53ce
Display FILALI JAOUHARI Abdeslam
tkRingSetting 4
CtiID 356 NOT MODIFIABLE
E164Mask
DialPlanWizardGenID
tkMWLPolicy 0
tkRingSetting_Consecutive 0
MaxNumCalls 4
BusyTrigger 4
CallInfoDisplayMask 9
LabelASCII FILALI JAOUHARI Abdeslam BLOCK
DisplayASCII FILALI JAOUHARI Abdeslam
tkRingSetting_ActivePickupAlert
tkRingSetting_IdlePickupAlert
SpeedDial
fkRecordingProfile
fkCallingSearchSpace_Monitoring
tkStatus_AudibleMWI 2
LogMissedCalls true
there is the second problem, do you have any idea to resolve this problem, please?
In attachement the warning message for more detail.
Thanks a lot,
Best regards,
Omar
06-21-2010 01:27 AM
Hi Omar
Do not use more than 30 Char in
* Label FILALI JAOUHARI Abdeslam BLOCKED*
* Display FILALI JAOUHARI Abdeslam*
* LabelASCII FILALI JAOUHARI Abdeslam BLOCK*
* DisplayASCII FILALI JAOUHARI Abdeslam*
It should work after them.
Roland Marti
07-05-2010 07:48 AM
Hi Roland,
Thanks for your answer,
I correct the error message bellow (I use less than 30 charc);
But, when I run DMA, I have always 2 kind of warnings messages :
First Message:
Row: 76 SQL error: -746(25040)
Error executing "update NumPlan set fkRoutePartition=NULL where pkid='6e4e4d45-b233-424e-ba5c-065421c445ee'": [Informix][Informix ODBC Driver][Informix]Unspecified System Error = -746. sqlerrm(25040)
pkid 6e4e4d45-b233-424e-ba5c-065421c445ee NOT MODIFIABLE
fkRoutePartition
DNOrPattern 7
tkPatternUsage 4 NOT MODIFIABLE
CFBDestination
CFNADestination
fkRouteFilter
tkNetworkLocation 0
fkDigitDiscardInstruction
PrefixDigitsOut
BlockEnable false
tkMixer
CalledPartyTransformationMask
fkCallingSearchSpace_SharedLineAppear 61779b5b-6941-4527-88ce-5baf31640078
fkDialPlan
fkCallingSearchSpace_Translation
CallingPartyTransformationMask
PatternUrgency false
tkStatus_useFullyQualCallingPartyNum 2
fkCallingSearchSpace_CFB
fkCallingSearchSpace_CFNA
DialPlanWizardGenID
UserHoldMOHAudioSourceID
NetworkHoldMOHAudioSourceID
CallForwardExpansionMask
tkAutoAnswer 0
PersonalRoutingEnabled false
DeviceFailureDN
fkCallingSearchSpace_DeviceFailure
CallingPartyPrefixDigits
fkCallingSearchSpace_MWI
fkVoiceMessagingProfile
CFBVoiceMailEnabled false
CFNAVoiceMailEnabled false
CFDFVoiceMailEnabled false
fkAARNeighborhood
withTag
withValueClause
Description
CFNADuration
tkPatternPrecedence 5
CFAPTVoiceMailEnabled false
CFAPTDestination
tkReleaseCauseValue 0
fkCallingSearchSpace_CFAPT
tkPresentationBit_ConnectedLine 0
tkPresentationBit_CallingName 0
tkPresentationBit_ConnectedName 0
tkPresentationBit_CallingLine 0
SupportOverlapSending false
CFAPTDuration
isCallable true
fkCallManager
AlertingName
AuthorizationCodeRequired false
AuthorizationLevelRequired 0
CFBIntDestination
CFBIntVoiceMailEnabled false
CFNAIntDestination
CFNAIntVoiceMailEnabled false
ClientCodeRequired false
CSSForCFA
fkCallingSearchSpace_CFBInt
fkCallingSearchSpace_PFF
fkCallingSearchSpace_PFFInt
PFF_CFB false
PFF_CFNA false
PFFDestination
PFFIntDestination
PFFIntVoiceMailEnabled false
PFFVoiceMailEnabled false
fkCallingSearchSpace_Reroute NOT MODIFIABLE
fkMatrix_Presence ad243d17-98b4-4118-8feb-5ff2e1b781ac
fkCallingSearchSpace_CFNAInt
IsMessageWaitingOn false
OutsideDialtone false
DeviceOverride false
AllowCTIControlFlag true
AlertingNameASCII
resetToggle false
tkReset 2
AARDestinationMask
AARKeepCallHistory true
AARVoiceMailEnabled false
CFHRDN
CFHRIntDN
CFHRIntVMEnabled false
CFHRVMEnabled false
CFURDestination
CFURIntDestination
CFURIntVoiceMailEnabled false
CFURVoiceMailEnabled false
fkCallingSearchSpace_CFHR
fkCallingSearchSpace_CFHRInt
fkCallingSearchSpace_CFUR
fkCallingSearchSpace_CFURInt
fkCallingSearchSpace_revert
HRDuration
HRInterval
ikNumPlan_ParkCode
RevertDestination
CFHRDuration
tkDeviceSecurityMode_MinimumAllowed
tkCFACSSActivationPolicy 0
fkResourcePriorityNamespace
tkNumberingPlan_Called 0
tkPriOfNumber_Called 0
tkPriOfNumber_Calling 0
tkNumberingPlan_Calling 0
fkDevice_IntercomDefault
DNOrPatternIPv6
tkStatus_PartyEntranceTone 2
ParkMonForwardNoRetrieveDN
ParkMonForwardNoRetrieveIntDN
ParkMonForwardNoRetrieveIntVMEnabled false
ParkMonForwardNoRetrieveVMEnabled false
fkCallingSearchSpace_PkMonFwdNoRet
fkCallingSearchSpace_PkMonFwdNoRetInt
ParkMonReversionTimer
Second message:
Row: 1046 SQL error: -746(35259)
Error executing "update PhoneButton set ButtonNum=22 where pkid='7926e6fd-7c8f-4966-8fa8-5c37c669f738'": [Informix][Informix ODBC Driver][Informix]Unspecified System Error = -746. sqlerrm(35259)
pkid 7926e6fd-7c8f-4966-8fa8-5c37c669f738 NOT MODIFIABLE
fkPhoneTemplate b7371212-0ddc-4fa2-9abd-37bd8848ad7c NOT MODIFIABLE
ButtonNum 22
tkFeature 255
Label None
ParamN1 14
ParamN2
ParamT1
ParamT2
isFixedFeature false NOT MODIFIABLE
resetToggle false
tkReset 2
if you have any ideas about what could the cause of those messages i'll be really grateful.
Best regards
Omar
