Military vehicle Solution Opportunity
pvasquesc
Hi to all,
What would be the best solution for a Military vehicle with small dimensions, with RDIS, 3G and IP connection.
The Edge 95 would be the right equipment?
What about a MOVI solution with Cisco Cius tablet only for IP connection?
The Head Office does not have any video-conferencing solution, yet.
Best Regards
Pedro
5 Replies 5
rsevier
If you looking for a soft client based solution MOVI is a great fit. It will perform like any other standards based endpoint.
The Cius would be a fit for an environment where you can leveage the bezel for wired, supported 3G provider or 802.11 wireless connections.
Hi rsrvier,
Thanks for the information.
I agree with you ... MOVI will fit the needs, but only for IP connections.
For ISDN connections, I will need for exemple, one Codec C40 and one Voice gateway 3241, to the Head Office. For the Vehicle, I just need the Edge95.
Would be great to have the old and discontinued Tactical MPX.
nbrocksc
Pedro,
There are a few Cisco Partners who have developed a "Tactical - Like" solution" using the C and EX series codecs.  CIS Secure is one that comes to mind.
