05-17-2015 10:31 AM - edited 03-17-2019 03:02 AM
Miscellaneous signaling debug data: (ch=1). When i start the router my voice card showing green light stable and not getting the dial tone. Kindly suggest how can i fix this issue.
05-17-2015 08:14 PM
You may need to provide more information on your environment. BUt have a look at this bug as well appears to be matching:
https://tools.cisco.com/bugsearch/bug/CSCse98109/?referring_site=bugquickviewclick
Miscellaneous signaling debug data" is popping up at bootup as below:
*Aug 2 11:58:18.943: Miscellaneous signaling debug data: (ch=11):
0008 0080 ABBA **
Conditions:
At bootup.
-Terry
Please rate all helpful posts
05-17-2015 11:07 PM
Hi Terry,
Pls take the following information and pls let me know if i can help you more.
show voice dsp.
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
----------------------------FLEX VOICE CARD 0 -----------------------
*DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND : (bad)bad (shut)shutdown (dpend)download pending
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
*DSP SIGNALING CHANNELS*
SP2600 001 01 {flex} 28.3.5 alloc idle 1 1 0/0/0 02 0 53/0
SP2600 001 02 {flex} 28.3.5 alloc idle 1 1 0/0/1 02 0 55/0
SP2600 001 03 {flex} 28.3.5 alloc idle 1 1 0/0/2 06 0 54/0
SP2600 001 04 {flex} 28.3.5 alloc idle 1 1 0/0/3 06 0 54/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
My IOS version.
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
May 18 05:46:55.911: Miscellaneous signaling debug data: (ch=1):
0000 0080 ABBA **
May 18 05:46:55.935: Miscellaneous signaling debug data: (ch=3):
0001 0080 ABBA **
07-14-2017 07:39 AM
in order to use PVDM2 on IOS 15, you must use router 2900 or above. I mean router 2800 whith pvdm2 not working well on IOS 15.
so if you have Router 2800 with pvdm2, don't use IOS 15, instead use ios 12.3(8)T4.
I'm currently using ios Version 12.4(5b) on 2811, everything is ok.
look at this table:
Table 3. Features Availability
