Hello, Helping a customer with an old UC560. They've advised that MWI isn't working. I didn't deploy the system, however the configuration all looks in order. They have the DN's for MWI on/off, the MWI string in the CUE application is correct, t...
dear all i have problem to access url cucm http site !telephony-service max-ephones 58 max-dn 64 ip source-address 192.168.2.207 port 2000 url services http://10.1.10.1/voiceview/common/login.do url authentication http://10.1.10.1/voiceview/authentic...
Hi, after a upgrade to Unity Connection 11.5 the LDAP import of user with special characters in lastname e.g. ö/ü/ä fail: Monday, October 9, 2017 9:14:43 AM CEST ERROR importing user (USERID) with extension = 2XXX: The specified column value is inv...
I just installed an 8831 conference phone in my CUCM 9.1.1 environment. The phone is registered and everything works but the time is off. It's seems like it is using GMT instead of my time zone.I've verified the device pool has the correct date/time ...
I'm working through the CCNA Voice lab workbook and I'm trying to test calls from one pod to the PSTN simulator. When I dial the digits, I get a fast busy and "unknown number"displayed on the phone. Debug dial-peer confirms my dial peers aren't being...
Hi, I installed CUCM and ipphone 8811 , 7861 and 7811I configured phone button template for 8881 ,7861 and 7811.for example i can add 10 speed dial button for 8811 . But i can see only left button (5 SD) on the phone. i can not see righ button.You ca...
Hello all, I have installed and configured CUCM v 11.5. the customer asks me to set up a scenario for the three operators standards. we have three standards : 8001 , 8002 and 8003. -he wants these three standards grouped on line 3000. and the...
Hi Guys, we are installing H323 gateway with Pri with 3 incoming digit but internal extention are configured with 4 digits in cucm. Please advise the voice translation-rule. pilot number: 4101000 incoming digits: 001 Internal Extention: 1001 voi...
So here is my story... I have created a home Cisco lab and would like to branch my VoIP network out to softphones as well as physical IP phones. The issue comes where I want to download the ip communicator software to implement but I can't download...
Does anyone know if a customer is not running Jabber (i.e. no IM&P installed), will Attend Console 11.0 still operate properly, with no errors. I understand it obviosly will not be able to show Jabber presence, but it should still show a person's pho...
Hi Viewers, Can anyone guide me to change the 7912 ip phone firmware to SIP? Thanks in Advance,...
Dear all, I've a Cisco 8831 connected on a Cisco CME 10.5, and i was upgraded the Cisco 8831 firmware from v9 to 10 (with sip8831.9-3-3-TO-10-3-1-v2 firmware) and after with sip8831.10-3-1-16 version and after with sip8831.10-3-1SR2-2. The sip8831....
Hi all, I want to forward some calls which hasn't been answered but I'm having this issue and need your help. So, here's the call flow : PSTN calling --reach--> IVR CUCX --press the ext number I know--> IP Phone ringing --forward call to mobile aft...
Hello all, I have installed and configured CUCM v 11.5. the customer asks me to set up a scenario for the three operators standards.we have three standards : 8001 , 8002 and 8003.-he wants these three standards grouped on line 3000. and the call want...
Hi Guys , I have Cisco IP Phone 7942 and it has top right on the screen my friends name . I want to change it to mine . Can you please help me how to change the display name on Cisco IP Phone 7942 . Waiting for your replies
| Subject | Author | Posted |
| 03-10-2026 12:08 PM | ||
| 03-04-2026 06:20 AM | ||
| 03-02-2026 07:40 AM | ||
| 03-02-2026 07:34 AM | ||
| 01-16-2026 03:24 AM |
