We currently utilize the service parameter "
We are implementing Mobile Connect on a number of employees.
The issue we have is when a call comes in from the PSTN to a mobile connect phone, the outbound call leg to the mobile phone prefixes the original calling part with the "91" so the callerid on the mobile phone appears as "91651XXXXXXX"
here's the Q931 output from the gateway:
LPP-PVG-1#
Jun 5 2012 11:26:23.078 CST6CDT: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x17B6
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838E
Exclusive, Channel 14
Calling Party Number i = 0x2183, '920750XXXX' <<< Inbound call from PSTN
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '7528' <<< DID of mobile connect user for inbound call
Plan:ISDN, Type:Subscriber(local)
Jun 5 2012 11:26:23.142 CST6CDT: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x97B6
Jun 5 2012 11:26:23.142 CST6CDT: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x97B6
Progress Ind i = 0x8088 - In-band info or appropriate now available
Jun 5 2012 11:26:23.226 CST6CDT: ISDN Se0/0/0:23 Q931: RX <- STATUS pd = 8 callref = 0x17B6
Cause i = 0x80E31E - Information element not implemented
Call State i = 0x07
Jun 5 2012 11:26:27.170 CST6CDT: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x03AE
Standard = CCITT
Channel ID i = 0xA98395
Exclusive, Channel 21
Calling Party Number i = 0x2183, '91920750XXXX' <<<< Original calling party with 91 prefixed to number
Called Party Number i = 0x80, '1320815XXXX' <<<< Correct 10 digit number for mobile phone
Plan:Unknown, Type:Unknown
Jun 5 2012 11:26:27.274 CST6CDT: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x83AE
How can I get the outbound call leg to show the "Calling Part Number" without the prefixed 91?
One suggestion I have on this is to use a different approcah to prefix the incoming calling party with the 91. Do not use the service parameters..I find it not so helpful. Rather use a translation pattern as described in the link below..Feel free to clarify if you dont understand anything
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805b6f33.shtml
Please rate useful posts
"I am complete in God, God completes me"
Thanks for the feedback on this. I think we will consider using the inbound translation pattern on the gateway vs a service parameter to give us more control at a granular level.
i did find a work around to this and its to create a new partition, CSS, Route List, Route Patterns, etc and on the Route List Member Information I specified the Calling Party Transform Mask to be XXXXXXXXXX which leaves just the 10 digits of the original calling party's number being sent in caller-id back to the PSTN and to the called party's mobile device.
