Mobile remote access question on phone configuration
schwabcm
Hello
We recently have been testing mobile remote access, MRA, for some of our users and have run into an odd situation.  When we add an additional DN to a telephone and that phone is taken home and connected via MRA, the 2nd line on the phone will not ring or flash as any call activity.  It can have calls made out on it, but cannot receive calls.  The main line on the phone works fine.
We've been told by Cisco that this is not able to be done, we are at 10.5.  Will any further versions take care of this issue?
Has anyone else had to deal with the same issue, and if so do you have a workaround?
thanks!
Carolyn
Jaime Valencia
What you're looking for, requires CUCM 11.5
See slide 10 for all requirements
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/release_note/Cisco-VCS-Release-Note-X8-9-1.pdf
java
if this helps, please rate
We are on CM 11.5 and are experiencing this same problem
11.5(SU2), not just 11.5 is required.
Please rate useful posts and mark answers as correct if applicable.
