Mobile voice access- Calling name not showing
ajayviswanath
  Hi All,
I am testing MVA. When i dial to an internal extension using MVA, the called phone shows only the calling number, it does not show the calling name.
Is this normal behavior..?? Thanks
AJ
6 Replies 6
ronpatel
Level 8
Level 8
What is the version of the CUCM you are using. If you are using CUCM 6.x it wil lnot display the Calling name and it will display only Calling number.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak,
I am using Cucm version : 7.0.1.11000-2. Does this version support calling name in MVA.
Dear friend
what type of protocol which you use MGCP or H323? .
Thank you
Hi Kamal,
Call comes in to a h323 gateway via  a PRI and it hits the vxml ivr script on the gateway using a dial peer.
AJ
Dear
Is this problem for any incoming call or for only MVA?. If answer yes , i think you have to go back to check with your teleco enable callre ID . Kindly use the below configuration
outer#config t
router(config)#
!– System based configuration
router(conf-serv-h323)#h323
router(conf-serv-h323)#h225 display-ie ccm-compatible
!– H323 Class based configuration
router(config)#voice class h323 1
router(config-class)#h225 timeout ntf 100
router(config-class)#h225 display-ie ccm-compatible
!– Interface Configuration
router(config-class)#int s0/2/0:23
router(config-if)#isdn supp-service name calling
thank you
islam kamal
Hi Kamal,
I am not sure how changing the config in the PRI would help, as i am calling into the MVA number then authenticate. I place an internal call to another extn, at this point the called phone shows the calling number(the internal extn associated with remote destination profile), however the calling name is not displayed. This issue seems to be internal to the cucm.
Any ideas
AJ
