HELP!!! CUBE and CUCM
khayes1984
I opened replied to a thread similar to this, but I need some assistance please!
I'm dealing with something similar to this but here's my flow
ISP/ITSP->ASA-CUBE->CUCMBE
Outbound calls work fine, it's inbound that's getting me...here's my config.
voice translation-rule 10
rule 1 /^\+1\(..........\)$/ /\1/
voice translation-profile in_rmv_plus1
translate called 10
dial-peer voice 100 voip
description Incoming dialpeer and 1+10 digits to Intelepeer
translation-profile incoming in_rmv_plus1
destination-pattern ^1[2-9]..[2-9]......$
session protocol sipv2
session target sip-server
session transport tcp
incoming called-number .T
voice-class codec 1
voice-class sip early-offer forced
dtmf-relay rtp-nte
dial-peer voice 101 voip
description 10-digit local calls to Intelepeer
destination-pattern ^[2-9]..[2-9]......$
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 102 voip
description International calls to Intelepeer
destination-pattern ^011T
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 103 voip
description N11 calls to Intelepeer
destination-pattern ^[2-9]11$
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 300 voip
description 20890138XX calls to primary CUCM
huntstop
preference 1
destination-pattern ^20890138..$
session target ipv4:192.168.1.8
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 302 voip
description Incoming calls from primary CUCM
huntstop
voice-class codec 1
dtmf-relay rtp-nte
gateway
timer receive-rtp 1200
sip-ua
retry invite 2
retry bye 2
retry cancel 2
retry register 10
sip-server ipv4:68.68.120.82
I don't require a UA username and password..
****Debug Output******
Mar 26 17:12:17.606: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=+12089013875, Called Number=+12089013875, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=+12089013875
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Mar 26 17:12:17.606: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=+12089013875, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1
Mar 26 17:12:17.606: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Mar 26 17:12:21.502: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Mar 26 17:12:21.502: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Mar 26 17:12:21.506: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
   Result=NO_MATCH(-1)
   Result=NO_MATCH(-1)
khayes1984
I've tried creating a dial-peer to match the number exact but no luck...Any suggestions?
Dear Keneth
please find the below configuration, if it will work ok we can fix all problems but firstly check the below. I hope also to delete 100 & 302 for only test  be sure that you have an ext
rule 1 /^+1\(..........\)$/ /\1/
translate called 10
voice-class codec 1
dtmf-relay rtp-nte
Thank you
please rate , if this will help
