mobile voice access - not able to place a call
pwenger
Level 3
Level 3
I setup voice mobile access on the CUCM 6.0 and on the h323 gateway. On the gateway I've got a BRI connecting to the PSTN.
I can reach the IVR, but when I try to place a call I immediately get disconnected. Find attached the q931 trace.
Does anyone have an idea why this happens?
Peter
myquick6
Did you ever get this resolved? I have 2 systems setup one works fine and the other has the same issue you have been seeing.
Thanks, JR
JR, did you find a fix for this problem. Having the exact same issue. Thanks
