05-15-2009 01:54 AM - edited 03-15-2019 06:02 PM
Hello netpro's
easy question I think.
UCM7 Mobility - I have a mobility profile configured and set up 3 external mobile numbers for 1 phone - when a calls comes into UCM 7 for the phone with mobility configured and all three mobile phone's ring - when a mobile answers the call - does that mean the session now exisits between the UCM 7 system and mobile, or does UCM 7 act as a redirector and the session exsist between the caller and mobile.
I hope I explained that clear enough - basically If I configure mobility for my company - will my company see an increase in telephone calls going out from UCM due to mobility.
Rod
05-18-2009 12:57 PM
Its a Mobile Connect Feature and in this scenerio when a call came in for an IP Phone and you configured remote destination for that phone.When that remote phone answers the call, the call originates from the UCM to the remote phone. Hence the relationship will be like this
Original Caller-->UCM-->Remote Phone
05-18-2009 01:24 PM
The SRND explains the whole process and even has diagrams
Mobile Connect Functionality
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/mobilapp.html#wp1043611
java
if this helps, please rate
05-18-2009 02:59 PM
The remote call CUCM makes is pretty much a share line appearance. And if you have 3 external phones dialing, that is three pstn channels you need (FYI) But once the call is connected... the IP phone and the remote destination are shared line appearances and they have certain functions between the two. The remote caller could put the call on hold, and the IP phone could pick it up. (remote caller is dropped then)
