Model TFU - 100A Bogen intergration with CUCM 8.6
Sam naik
Hi Team,
We did Valcom paging using FXO integration with CUCM recently and it's working fine. We are in process to intergrate another paging system Model TFU - 100A Bogen with CUCM 8.6.
I believe it would be the same procedure as Valcom, but it would be great if we get some information about the reqirement and how to setup this (Document)?
Sam
Rob Huffman
Hi Sam,
Every person I've ever worked with here has had to use a "mid-point" integration peice like the TAMB-2 (see link) between the FXS/FXO and Bogen
http://www.bogen.com/products/telephonepaging/index.html
Cheers!
Rob
PS: you can also use the original TAMB (google) for a cheaper co$t
"Everything is broken" - Bob Dylan
Hi Rob,
Thanks for the message. It’s seem that it have to have require “Mid Piece” device i.e TAMB2. We are planning to use FXO to Bogen. Is there any other option available with this piece please.
Sam
                   Thanks for the information. Appreciated
Rob Huffman
Hi Sam,
The TAMB2 or "older " TAMB both work with FXO circuits so you would be good to go These
are both pretty cheap part$ with the TAMB being the cheapest. Without this piece
you will have trouble bridging between the phone system and the Bogem Amp unless it
has a direct connect FXO/FXS capability which I doubt it does.
Station Port Compatibility: Two-wire ring start
Trunk Port Compatibility: Two-wire loop start or ground start
http://www.bogen.com/products/pdfs/telephonepagepdfs/TAMB2s.pdf
Cheers!
Rob
