Modify REFER SIP message Cisco 8961
willsupport
we configured for our customer some 8961 ip phones with 3cx. We created the required templates and the calls are working fine.
The problem occur when someone wants to forward a call. The phone sends the following message:
REFER sip:x.x.x.x SIP/2.0
Via: SIP/2.0/UDP x.x.x.x:5060;branch=z9hG4bK38eaf9d1
From: <sip:xxxx@x.x.x.x>;tag=84802d77c0fd0010520724f9-20198d62
To: "xxxxxxxx"<sip:xxxxxxxx@xxxxxx:5060;nf=e>
Call-ID: OutOfDialog--0009-0eb9312f-33116ed5@x.x.x.x
Max-Forwards: 70
Date: Fri, 01 Jan 1982 00:15:53 GMT
CSeq: 101 REFER
User-Agent: Cisco-CP8961/9.4.2
Contact: <sip:xxxx@x.x.x.x:5060;transport=udp>
Referred-By: <sip:xxxxx@xxxxxxx>
Refer-To: cid:56458189@x.x.x.x
Require: norefersub
Proxy-Authorization: Digest username="xxxxxxxxxxxxxxx",realm="3CXPhoneSystem",uri="sip:x.x.x.x",response="a95853e3e5ee1986e6a14140230ff1e8",nonce="414d53596617ee4c52:4b0c678c53f75cc496fb6efe82e4ee4f",algorithm=MD5
Content-Length: 926
Content-Type: application/x-cisco-remotecc-request+xml
Content-Disposition: session;handling=required
Content-Id: <56458189@x.x.x.x>
And from the 3cx server i receive:
SIP/2.0 420 Bad Extension
To: "xxxxx"<sip:xxxxxxxx@xxxxxxxxxxx:5060;nf=e>;tag=c80e5242
From: <sip:xxxxxx@x.x.x.x>;tag=84802d77c0fd0010520724f9-20198d62
CSeq: 101 REFER
Unsupported: norefersub
Content-Length: 0
Is there a way to delete or change that "Require" in the SIP message?
Alessandro
vLoz
Hi Alessandro,
I think an option can be modifying or removing throught a SIP Translation Profile: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-sip-param-mod.html#task_0DC87B03479A4DD9A81AD2E405CA8EC9
Greetings, Vladimir.
