09-02-2009 02:16 PM - edited 03-15-2019 07:36 PM
I have always been under the impression that when enabling Multicast MOH from the CUCM and enabling the 'increment by port' that it starts at whatever port number you enter and then creates 4 new ports for every source that are based on the audio source number as an index.
So, for example if you are on source (1) and you started at port 16384 (the default) that the 4 streams would be at 16384, 16386, 16388, and 16990. And based on that the mathmatical formula for calculating the first port (g711ulaw port) in the sequence would be...
x+((y-1)*8), where x is the starting port number and y is the audio source number index.
So, in in the previous example that would be 16384+((1-1)*8) or 16384.
for audio source 5 it would be 16384+((5-1)*8) or 16416.
I am working on a 6.1.2 deployment where it seems like this is not true. It seems like rather than using the audio source number as the index it is incrementing these based on order of entry. So if audio source number 5 was created immediately after source 1 then it takes over the next 4 ports or 16392, 16394, 16396, and 16398. Then, if you create source 2 later it falls numerically behind source 5 in the ports used. This behavior, if true, makes it hard to predict where the Multicast ports are used. The reason this is important to me is that I am using the MMOH on flash procedure to source MMOH locally at remote sites from flash rather than across a non-multicast emabled WAN. You can only enable one port per site, and if you're wrong you get MOH silence.
thanks for your help,
Has anyone observed this or can help me explain/fix?
09-08-2009 01:24 PM
239.255.255.255. The Internet Assigned Numbers Authority (IANA), however, assigns addresses in the range 224.0.1.0 to 238.255.255.255 for public multicast applications. Cisco strongly discourages using public multicast addresses for music on hold. Instead, Cisco recommends that you configure multicast MoH audio sources to use IP addresses in the range 239.1.1.1 to 239.255.255.255, which is reserved for administratively controlled applications on private networks.
Furthermore, you should configure multicast audio sources to increment on the IP address and not the port number, for the following reasons:
â¢IP phones placed on hold join multicast IP addresses, not port numbers.
Cisco IP phones have no concept of multicast port numbers. Therefore, if all the configured codecs for a particular audio stream transmit to the same multicast IP address (even on different port numbers), all streams will be sent to the IP phone even though only one stream is needed. This has the potential of saturating the network with unnecessary traffic because the IP phone is capable of receiving only a single MoH stream.
â¢IP network routers route multicast based on IP addresses, not port numbers.
Routers have no concept of multicast port numbers. Thus, when it encounters multiple streams sent to the same multicast group address (even on different port numbers), the router forwards all streams of the multicast group. Because only one stream is needed, network bandwidth is over-utilized and network congestion can eventually result.
09-08-2009 01:39 PM
Sorry, I don't think I got all your post, can you rephrase?
Regarding what I did see, I am using 239.1.1.1, the default.
Also, i am not streaming all sources. I am using local flash to 'spoof' the multicast stream if you will. I am not routing multicast over the WAN and not saturating.
Are you familiar with this document?
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802d1c31.html
09-08-2009 02:01 PM
One other note, regardless of what method (ip address, or port) used, if the audio source is not used correctly as an index, it won't be predictable.
