monitor event-trace arp command
markbohush
I have a C4507 core switch that because of a NEC phone system we are having some issues with calls. What I need to do is to shut off the arp IP monitoring on the switch. I have the command monitor event-trace arp and want to know if disable will stop the IP tracing and also if I do it in production hours will it affect the people currently connected.
0 Replies 0
