UCS240 M3 System status LED Amber blinking
cristian.munoz
Level 4
Level 4
Hi Guys
I have a alarm in the UCS240 . The System status LED Amber is blinking, but in the vCenter nothing appears abnormal.
Please see the captures:
-System Event
-System Status
- CPU
- Memory
- Storage
-Temperature
-Platform Alert
TIA
Cristian
5 Replies 5
eric.ahernandez
Hi Cristian,
Have you tried login in to CIMC of the UCS and look at the Dashboard and logs of the UCS on Server > System Event Logs and Server > Fault Sumary
Hi Eric
I have a capture of Fault Summary. Please see the attachment,
Dear Eric
Time :Fri Dec 20 12:55:17 2013
Severity :Warning
Code :F1008
DN :sys/rack-unit-1/board/storage-FLASH-ctlr-1/vd-HV
Probable Cause :equipmentDegraded
Description :Flex Flash Virtual Drive HV Degraded: please check the flash device or the controller
TIA.
Cristian
Hi Cristian,
That warning leads me to believe you have a fault on your Flex Flash Card (which is the internal SD Card on your UCS Server) particularly on the HV Virtual Drive or Partition which is used for the ESXi Hypervisor.
If you're not using this Virtual Drive then there's no problem, but if you do or plan to use it in the future I'd advise to open a TAC Case to see what can be done (probably an RMA, not sure if for the entire chassis or just the SD Card).
Hello
Finally the issue was solved , shut down the UCS (unplug the power supply).
Thanks for all
Cristian
