Monitor PRI status
ls440
Hello all,
 I have urgent requirement to monitor the PRI status in terms of and calls connectivity. I could test the call connectivity via
 snmpwalk -v -c Public hostname but I get many  ifIndex,MIB and OID. how could i monitor the status? is there any nagios check?
Is it possible through RTMT tool?
16 Replies 16
this oid works and i get Gauge32: 0
but i would like to monitor the pri interface status of "show isdn status" Layer 2 statistics which says PRI is up
panicatthecisco
Would a report that shows you concurrent calls on your device help?  Something like these attached.
-Edgar Salazar
