Moving IP phone to new physcial location does NOT work
bfpnetworking
I have a non-Cisco ip phone that works.  After making three more new wall ports Hot with POE and VOIP, I moved the working ip phone to one of the three new switch ports.  The phone powers up and displays a crc error.  The Cisco 2960S port goes green, but the phone does not work.
This is a non-Cisco PBX with proprietary DHCP...
Any ideas?
singhaam007
Level 3
Level 3
Possibly cabling issue.
Try this command
=test cable tdr int
And then show cable tdr int
From the out put see if pair c is normal or open. If its open the possible a cabling issue.
It suppose to be normal.
Please rate if this helps
thanks
I get the above symptom plugging directly into the 2960S switch.
The port where i plugged into the phone was configured like this:
switchport trunk allowed vlan 1,2
switchport mode trunk
switchport nonegotiate
priority-queue out
mls qos trust cos
spanning-tree portfast trunk
spanning-tree bpduguard enable
priority-queue out
mls qos trust cos
I then changed it to the below, thinking that the portfast or bpduguard could interrupt the phone registration??
priority-queue out
mls qos trust cos
Any thoughts?
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 16:56 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01B00000
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(53r)SE, RELEASE SOFTWARE (fc3)
GVS12SW06GBPOE uptime is 15 weeks, 5 days, 1 hour, 33 minutes
System restarted at 06:56:07 cst Fri Jun 8 2012
System image file is "flash:/c2960s-universalk9-mz.122-55.SE3/c2960s-universalk9-mz.122-55.SE3.bin"
try this
switchport trunk native vlan XXX (your data vlan)
switchport trunk allowed vlan XXX,XXX
switchport voice vlan XXX (your voice vlan)
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
hope this will help.
thanks
