Moving large number of CUCM translation patterns to different partition ?
markhayek
CUCM 8.5
Has anyone found a way to move a large number of translation patterns from partition A  to partition B , using a BULK edit method ?
BULK tool seems to only allow edit to users, phones, lines.  THe only method we found was to EXPORT all trans patterns, EDIT the ones we want, then IMPORT them back in.  However, this does not DELETE the previous ones, only adds new ones on the new partition.
It seems we would have to import, then delete all using the GUI with a custom search.
Chris Deren
Your best bet is to use import/export feature, so export the TPs, adjust the partitions and import them, then you can delete the old TPs.
HTH,
Chris
iptuser55
Level 6
Level 6
You can always look at it another way.  How many CSS, DN`s use the TP partition, you can always rename the TP and then manually or use BAT to  change the other occurances to another Partition?
