ms teams direct routing to cube
mark007
Afternoon
We are trying to try direct routing with teams via our cube and we are getting a codec error when calling from teams to the cube.
I am at a loss where the issue is we are not hitting a dial peer
I have attached the config and debug ccsip messages
Ashish Patel
You've gone through this in detail right?
https://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise/interoperability-portal/direct-routing-with-cube.pdf
Then get this to take a better look at the logs if that helps https://translatorx.org/index.html
if nothing else you might have to open a TAC case.
Response Signature
Ashish Patel
Response Signature
