CUCM Subscriber SNMP not working
aphommathep
Good afternoon! Hopefully someone will be able to help me out. I am unable to get SNMP working on our CM subscriber. The service is started, the server is pingable, and I am able to create the strings, but I cannot actually get the SNMP to work on this one box. Thanks in advance for any help you can provide!
Andrew Skelly
Level 7
Level 7
Did you restart the SNMP master agent on the server you added SNMP to?  Also did you configure v2 or v3?  Make sure that your monitoring tool is also using the same version.
Please rate helpful posts by clicking the thumbs up!
aphommathep
Andrew,
Thanks for the help! Yes, I have restarted the service and the server has restarted since configuring. I am attempting to configure v1.
John
I am assuming you completed the setup of snmp v1/v2 from cucm
serviceability. If so, run a packet capture on your NMS to see if SNMP
message exchange is happening. You can run it on cucm as well using utils
network capture but I prefer to do it on NMS
**** please remember to rate useful posts
