MSSQLServer Event Log
davidme
HI,
I keep getting the following application event in event viewer.
Event Type: Information
Event Source: MSSQLSERVER
Event Category: (2)
Event ID: 17052
Date: 22/02/2007
Time: 22:38:39
User: SGPUBLISHER\Administrator
Computer: SGPUBLISHER
Description:
Error: 15457, Severity: 0, State: 1
Configuration option 'show advanced options' changed from 1 to 1. Run the RECONFIGURE statement to install.
Data:
0000: 61 3c 00 00 00 00 00 00 a<......
0008: 0c 00 00 00 53 00 47 00 ....S.G.
0010: 50 00 55 00 42 00 4c 00 P.U.B.L.
0018: 49 00 53 00 48 00 45 00 I.S.H.E.
0020: 52 00 00 00 07 00 00 00 R.......
0028: 6d 00 61 00 73 00 74 00 m.a.s.t.
0030: 65 00 72 00 00 00 e.r...
Anyone got any ideas how I can clear this????
Cheers
Dave
mchandak
Level 7
Level 7
his error is usually related to DBLHelper left running in onebor more callmanagers in the cluster. Can you check to see if DBLHelper.exe is running and shut it down.
