03-03-2015 06:55 AM - edited 03-17-2019 02:11 AM
I have one h323 gateway and registered in CUCM. I have not checked Media Termination Point Required. Then the problem was that incoming calls were on way voice.
When i have checked Media Termination Point Required option then it is OK. What can be the issue? if i dont want to enable this option. Thanks
03-03-2015 08:16 PM
Where is the MTP resource located? Is this the same voice gateway or the CUCM or another ISR?
Maybe check your routing to/from voice gateway from CUCM. Do you have any load balancing config like HSRP, VRRP etc in place.
03-03-2015 09:02 PM
MTP are located on same gateway.
Routing is perfect as i told you when i check that option then 2 way voice happens.
