MTP not registering in cucm (MTP Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR)
monasir
Hi all,
I'm not able to get my MTP registered in cucm, ive configured sccp /groups/dspfarm however no succes:
Registration status in cucm (Unknown)
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0/0
        IPv4 Address: 123.45.67.89
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 12.34.56.78, Port Number: 2000
                Priority: 1, Version: 7.0, Identifier: 2
                Priority: 2, Version: 7.0, Identifier: 1
Active Call Manager: NONE
TCP Link Status: CONNECT_PENDING, Profile Identifier: 2
Reported Max Streams: 200, Reported Max OOS Streams: 0
Supported Codec: pass-thru, Maximum Packetization Period: N/A
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period           : 30
TLS : ENABLED
DSP groups on slot 0/4 slot id 4
dsp 1:
  State: UP, firmware: 40.2.10
  Max signal/voice channel: 32/32
  Max credits: 480, Voice credits: 480, Video credits: 0
  num_of_sig_chnls_allocated: 0
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 480, reserved credits: 0
    Signaling channels allocated: 0
    Voice channels allocated: 0
    Credits used (rounded-up): 0
  Slot: 0/4
  Device idx: 0
  Dsp Type: SP2700
sccp local GigabitEthernet0/0/0
sccp ccm 10.12.34.56 identifier 1 priority 2 version 7.0
sccp ccm 10.12.34.78 identifier 2 priority 1 version 7.0
sccp
sccp ccm group 1
 bind interface GigabitEthernet0/0/0
 associate ccm 1 priority 1
 associate ccm 2 priority 2
 associate profile 1 register TEST1-MTP1
 associate profile 2 register TEST2-MTP2
dspfarm profile 1 mtp
 codec g711ulaw
 codec pass-through
 maximum sessions software 100
 associate application CUBE
dspfarm profile 2 mtp
 codec g711ulaw
 codec pass-through
 associate application SCCP
In cucm i gave it the same name (TEST1-MTP1) (TEST2-MTP2)
And put it in a devicepool
Am i missing something in my configuration part or what??
will.alvord
Level 5
Level 5
Your LTI MTP won’t register to cucm (assoc app cube) but the other one should. You might try bouncing sccp (no sccp; sccp).
Hi will.alvord
Ive already tried that unfortunately it didnt work for me
