Multicast MoH "hub and spoke" not work with call From PSTN.
Hi friends,
sorry but I've got a problem, in the architecture specified in the title, i can't hear MoH only in one site. What can be the problem? i attach some debug. Thanks for all answer!
5 Replies 5
Chris Deren
Can you post your GW configuration?
Are you playing MOH from flash or is it multicast traffic to the remote location?
If from flash make sure you have loopback ip address referenced in the "mulicast moh" command.
Chris
is from flash, in attach the configuration.
Your configuration looks OK, here are some tips that have worked for me in the past:
remove both moh commands under fallback and add them again
if that does not work try:
remove and re-add "ccm-manager music-on-hold"
reboot the router
Chris
ok now i try, then I let you know!
ok now it working good!
