03-31-2016 09:34 PM - edited 03-17-2019 06:26 AM
Can I configure a custom default value for the Multiple Call / Call waiting settings?
CUCM 10.5
For example with 7960's the default is:
Maximum Number of Calls 4
Busy Trigger 2
I would like to change this value to 5 and 3 respectively, however, I
do not want to have to remember to change it for each new user.
03-31-2016 09:55 PM
Dont think so there is a Service Param etc. where you can change this value globally. If you want to update multiple phones or all phones - Use BAT>Phones>Add/Update Lines.
-Terry
Please rate all helpful posts
03-31-2016 10:08 PM
Terry is spot on with the answer, just filter the phone based on model, device pool and update the following parameter in the bulk update:
Multiple Call/Call Waiting Settings on Device
