Multiple ISDN Switch Types
VAbr AVib
How to configure multiple switch types on a Cisco Voice Router ? Attaching the diagram for reference.
I need to connect one PRI card to the PBX and the other card to the PSTN PRI.
I am having Cisco 2951 series router? Does this router support multiple PRI Connectivity ?
Vibi,
I think this may help you.
In this config we have 7 PRIs
6 are for PSTN and 1 for QSIG.
We are taking the clock from the PSTN and
if they all fail we use the clock from the
PBX QSIG
We are also emulating the network end for the QSIG PBX link.
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-participate wic 3
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/0/1
network-clock-select 3 E1 0/1/0
network-clock-select 4 E1 0/1/1
network-clock-select 5 E1 0/2/0
network-clock-select 6 E1 0/2/1
network-clock-select 7 E1 0/3/0
isdn switch-type primary-net5
interface Serial0/0/0:15
desc *** TO PSTN ***
isdn overlap-receiving T302 2000
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:15
no cdp enable
interface Serial0/1/0:15
no cdp enable
interface Serial0/1/1:15
no cdp enable
interface Serial0/2/0:15
no cdp enable
interface Serial0/2/1:15
no cdp enable
interface Serial0/3/0:15
desc *** TO PBX QSIG ***
isdn switch-type primary-qsig
isdn timer T310 120000
isdn protocol-emulate network
no cdp enable
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
14 Replies 14
Harmit Singh
Hi Vibi,
Yes, it does. The thing to watch out for is clocking. If the router is receiving the clock from both PBX and PSTN provider, then you need to make sure both PRIs terminate in seperate clocking domains to avoid slips. In other words, your motherboard would be one clocking domain while you could go with an NM-HDV2 module which would serve as the second clocking domain. As for the switch-types, you can specify each switch-type under the Serial Interface of each PRI. This config takes precedence over the global switch-type configuration.
HTH.
Harmit.
Thanks a lot Harmit.
In that case how do i mention the switch type? I should anyway mention the switch type globally and then at the interface level.
Also just found this link where they say, multiple ISDN switch type is supported for the mentioned platforms only.
http://www.cisco.com/en/US/docs/ios/11_3/feature/guide/multisdn.html#wp7721
Platforms:
This feature is supported on these platforms:
Cisco 3600 series
Cisco 4000 series
Cisco 5200
Cisco 5300
Cisco 7200 series
Cisco 7500 series
Hi Vibi,
That document is very old and refers to IOS version 11.x :-)
However, the logic it mentions is still the same. The command is "isdn switch-type " where type is whatever switch-type you need to configure. Apply this under the serial interface once the PRIs are configured.
HTH.
Harmit.
As you told let me check the clocking settings, also i should go for NM-HDV2 module right.......
Thanks a lot.....
Yes, look for "Analog and Digital Voice/Fax" in the following doc:
http://www.cisco.com/en/US/products/ps10536/products_relevant_interfaces_and_modules.html#voicemod
Harmit.
Vibi,
PBX QSIG
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
no cdp enable
Alex.
Thanks a lot Alex for your detailed note. Could you please verify the dial peer in this case ?
I am planning to have the below dial peers for PBX extensions and PSTN calling:
dial-peer voice 15 pots
  destination-pattern 3...     'PBX Extensions 3XXX
  incoming called-number .T
  port 0/0/0:15              ' Connected to PBX
  forward-digits all
dial-peer voice 16 pots
  port 0/0/1:15         ' Connected to PBX
  forward-digits all
dial-peer voice 17 pots
  destination-pattern 86.T        ' PSTN Access Code '86'
  direct-inward-dial
  port 0/1/0:15           ' Connected to PSTN
dial-peer voice 18 pots
  direct-inward-dial
  port 0/1/1:15          ' Connected to PSTN
Vibi,
Primarily your dial peers are good.
May be you need to consider how you want the outgoing
calls to flow.
You can set a preference in each dial peer.
Lets say you want the outgoings calls to always use the
1st PRI and use the 2nd choice if all channels are busy.
forward-digits all
pref 1
forward-digits all
pref 2
direct-inward-dial
pref 1
direct-inward-dial
pref 2
Alex.
Alex, Thanks a lot for your valuable comments.
Looking at the DSP requirements since more resouces might be required when we have both PSTN and PBX terminating on the same router. I have two DSP (PVDM3-32,PVDM3-64) and the maximum channel usage currently is around 20 CH during peak hours. Do I need to add more DSP's ?
Vibi,
If you want to run all 4 PRIs with full 30 channel capacity you will
need to add or change your DSP set up.
As a minimum you need to upgrade the PVDM3-32 to a PVDM3-64
Please remember that this will leave you with no additionalo DSP resources to provide
IOS trancoding,conferencing or MTP.
If you can afford (money) then replace the PVDM3-32 with a PVDM3-128.
Hope this helps
Alex.
We will not have much load on the router except for the timeslots and transcoding.
The Router model 2951 has 3 DSP slots, I think it is better we add another chip of PVDM3-64 (Total=> 32+64+64). So if am not buying any more DSP's then I think I have to reduce the timelots for PBX PRI ports ?
CUCM Software  MTP and Conference Bridge is used and following is the IOS transcoder details.
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
codec g722-64
maximum sessions 10
associate application SCCP
Alex, Your thoughts !!!!
Vibi,
I have just ran your dsp commitments through the dsp calculator
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
To run full 120 channels over the 4 E1 PRIs and 10 session Transcoder you will need
PVDM3-192
You will need to cut down the channels,
looks like you would need to reduce to 106 channels & 10 sess transcode
Try the calculator yourself
Alex.
Thanks a lot Alex.
As you told i will work on the channel requirements, i will monitor the channel usage trend and finalize the max number of channels required for both PBX and PRI ports. So based on that can decide what sort of DSP change is required. As you suggested, if i plan for 60 PSTN channels and 46 PBX channels we still need another PVDM3-64 right? And since i am adding PSTN to the new PRI card, do you think we need to add more transcoding sessions or 10 is sufficent ?
I also noticed that there is one error message when i run "sh voice dsp group all" stating "4 DSP resource allocation failure", i need find out the cause for that as well.
Do you have any idea why there is a DSP failure when the number of channels used are below 10 ?
Vibi,
You could be hitting a BUG
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsx67255
The follwing IOS versions are affected
15.0(1r)
15.0(1r)M1
15.0(1r)M2
15.0(1r)M3
15.0(1r)M4
15.0(1r)M5
15.0(1r)M6
15.0(1r)M7
15.0(1r)M8
15.0(1r)M9
15.0(1r)M10
15.0(1r)M11
15.0(1r)M12
15.0(1r)M13
15.0(1r)M14
15.0(1r)M15
15.1(2r)T
15.1(2r)T1
15.1(2r)T2
15.1(2r)T3
Alex.
