07-01-2013 02:18 PM - edited 03-16-2019 06:10 PM
User needs an extension -- which doubles up to be a MVA directory number ( not assigned on any phone ) to have restrictions .
For now when we dial that number from inside you get prompted with a dial tone and are able to dial international calls. *** We are not authorized to change the partition as well ***
Any suggestions on how to proceed on it .
CCM version : 7.x
Whatever level you reach getting better never stops -- Sachin Tendulkar
07-02-2013 03:47 AM
No way to do that if you cannot change the partition on the Number.
Tapan
07-02-2013 03:51 AM
In addition to above take a look at the
System Remote Access Blocked Numbers service parameter field
Which allows administrators to block Certain numbers to be dialed from RD phones of MVA or EFA users
Tapan
07-02-2013 02:06 PM
Thanks for the response
Let me check the parameters as mentioned above and get back .
