MWI madness - UC560/7965 handsets
davidfield
Participant
Participant
Hello All,
I'm positive I've read and tried almost every recommendation on Message Wait Indicator to get it to work on my 7965 handsets with UC560.
I can leave a voicemail at the extension 210.  I can dial 399 and listen to my voicemails from extension 210. I can see the A800 in the ccsip debug being sent to 210.  I'll put this out there but surely I don't need to reboot the phone or uc560 after making the changes to resync MWI.
The entries in the service engine config match the ephone settings on the config.
I've attached:
- UC560 config
- SIP ccsip debug
- Service Module config
Any pointers greatly appreciated.
David
7 Replies 7
davidfield
Participant
Participant
Below is the debug after hangup of leaving voicemail message.  In bold underlined below is the MWI send "ON".  So totally confused now.  Any ideas anyone?
004217: Aug 11 12:39:31.894: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x01
        Cause i = 0x8090 - Normal call clearing
        Progress Ind i = 0x8288 - In-band info or appropriate now available
004218: Aug 11 12:39:31.894: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1  disconnected from unknown , call lasted 19 seconds
004219: Aug 11 12:39:31.898: //804/BFFA590489AB/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:399@10.1.10.1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.1.10.2:5060;x-route-tag="tgrp:ALL_BRI";branch=z9hG4bK15A336
To: <399>;tag=ds91ee3860
Date: Thu, 11 Aug 2011 12:39:12 GMT
Call-ID: BFFAF52C-C34D11E0-89AECA6B-19482E35@10.1.10.2
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1313066371
CSeq: 102 BYE
Reason: Q.850;cause=16
Content-Length: 0
004220: Aug 11 12:39:31.902: //804/BFFA590489AB/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
Via: SIP/2.0/UDP 10.1.10.2:5060;branch=z9hG4bK15A336;x-route-tag="tgrp:ALL_BRI"
CSeq: 102 BYE
Content-Length: 0
004221: Aug 11 12:39:31.922: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8  callref = 0x81
004222: Aug 11 12:39:31.966: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8  callrse-30-1-1-2#
se-30-1-1-2# Aug 11 13:39:37 localhost java:   ERROR ccn StackSip DBUG  ##### ltp119-399, State=DISCONNECTED:  ##### [SIP-Local-MT-118 dn=399 media=10.1.10.1:32812, mediaStarted=false] ##### [SIP-Remote-MT-119 dn=A800210 no media]: ##### ltp119-399, State=DISCONNECTED:  ##### [SIP-Local-MT-118 dn=399 media=10.1.10.1:32812, m
se-30-1-1-2#
ok.  I think Im onto something.  In The service module the SIP gateway is showing as 30.1.1.1
ccn subsystem sip
gateway address "30.1.1.1"
end subsystem
Whereas in the 560 config I only have 10.0.0.0/8 and 192.0.0.0/8 ranges.  Where did this IP come from as I knwo I didn't enter it? and am I correct in thinking it should be 10.1.10.2 as in the interface below?  Or should it be the address of my voice vlan 90?
interface GigabitEthernet0/1/3
description Interface used to communicate with integrated service module
switchport access vlan 90
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
Can anyone confirm?
Nope still having the issue with MWI.  Is anyone able to review my config and assist?  The client is driving me nuts wanting his flashing light.
I wish I had an answer for you,  but I'm in the same boat right now....I have mostly 7945 phones connecting to a freshly installed UC560, and have no MWI on any phone.
I don't know where your 30.1.1.1 address came from...I reviewed mine and is it set to 10.1.10.2
Have you had any luck in resolving your issue?
I don't know that this will help you out or not....but in doing some guess/testing...I was able to get MWI to work with our 79xx phones when I changed MWI to Unsolicited Notify.
I used the web GUI to make the change on the CUE  (Voice Mail > Message Waiting Ind > Settings)
Then made changes via CLI on the UC560:
sip-ua
mwi-server ipv4:10.1.10.1 expires 3600 port 5060 transport udp unsolicited
Don't know if this will help you or not....just figured what looks to be a "good enough" fix for my issue.
David,
Does not look like the CUE is sending the INVTE to the UC560 for the MWI to turn on.
If you call from an IP phone to A800210, does that turn on the MWI?
You said you saw the A800 on the debugs, would that be on the attached debugs? I didn't see them.
Luis Ramirez.
Thanks guys, I shall test and advise on outcomes.
Dave
