06-04-2016 12:32 PM - edited 03-17-2019 07:08 AM
When someone calls in and leaves a voicemail message the message waiting light does not appear.
What is wrong?
EVERYTHING IS SIP
show configuration
CME:
voice register dn 41
number 849
call-forward b2bua busy 1000
call-forward b2bua mailbox 1000
call-forward b2bua noan 1000 timeout 10
allow watch
pickup-call any-group
pickup-group 10
name Nadia
label 849 Nadia
mwi
sip-ua
mwi-server ipv4:172.16.1.2 expires 3600 port 5060 transport udp unsolicited
telephony-service
max-dn 58
service phone videoCapability 1
service dnis dir-lookup
timeouts interdigit 3
timeouts ringing 30
url services http://172.16.1.2/voiceview/common/login.do
url authentication http://172.16.1.1/CCMCIP/authenticate.asp
voicemail 1000
mwi relay
GATEWAY#SHOW VOICE REGister GLobal
CONFIG [Version=10.0]
Version 10.0
Mode is cme
Max-pool is 55
Max-dn is 55
Outbound-proxy is enabled and will use global configured value
Security Policy: DEVICE-DEFAULT
Forced Authorization Code Refer is enabled
Source-address is 172.16.1.1 port 5060
Authenticate register
Authenticate realm lab.local
NTP Server Address is 172.16.1.1
NTP Server Mode is: directedbroadcast
Time-format is 24
Date-format is D/M/Y
Time-zone is 9
Hold-alert is disabled
Mwi stutter is enabled
Mwi registration for full E.164 is enabled
CUE
CUEGNP# sh ccn subsystem sip
SIP Gateway: 172.16.1.1
SIP Port Number: 5060
DTMF Relay: sip-notify,sub-notify
MWI Notification: unsolicited
MWI Envelope Info: disabled
Transfer Mode: bye-also
Transfer Timeout: 6
SIP RFC Compliance:
CUEGNP# sh ccn application
Description: Cisco Auto-Attendant
Application type: aa
Script: aa.aef
ID number: 1
Enabled: yes
Maximum number of sessions: 2
allowExternalTransfers: true
busClosedPrompt: AABusinessClosed.wav
businessSchedule: systemschedule
busOpenPrompt: Conmutador_aps_1.wav
dialByExtnAnytime: true
dialByExtnAnytimeInputLength: 3
dialByFirstName: false
disconnectAfterMenu: false
holidayPrompt: AAHolidayPrompt.wav
MaxRetry: 0
operExtn: 800
welcomePrompt: Conmutador_aps_3segs_1u.wav
Description: promptmgmt
Script: promptmgmt.aef
ID number: 4
Enabled: yes
Maximum number of sessions: 1
appManagementScript:
Description: Cisco Voicemail
Script: voicebrowser.aef
ID number: 2
Enabled: yes
logoutUri: http://localhost/voicemail/vxmlscripts/mbxLogout.jsp
uri: http://localhost/voicemail/vxmlscripts/login.vxml
Description: msgnotification
Script: msgnotify.aef
ID number: 5
Enabled: yes
Maximum number of sessions: 10
DelayBeforeSendDTMF: 1
Description: ciscomwiapplication
Script: setmwi.aef
ID number: 3
Enabled: yes
CallControlGroupID: 0
strMWI_OFF_DN: 8001
strMWI_ON_DN: 8000
06-04-2016 06:33 PM
It looks like you have
Can you paste CUE config, also you can do a debug
06-06-2016 09:18 AM
Copy configuration of the cue:
You see a mistake ??
Within hours sending the debug
CUEGNP# sh run
Generating configuration:
clock timezone America/Mexico_City
hostname CUEGNP
line console
system language preferred "es_MX"
software download server url "ftp://127.0.0.1/ftp" credentials hidden "6u/dKTN/hsEuSAEfw40XlF2eFHnZfyUTSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
site name local
phone-authentication credentials hidden "MCLALjrKGaC6CC4IAfw7AOhe6k0i+EmBAyZmX0tax/W4H2gZLIbsvknfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
site-hostname 172.16.1.1
web credentials hidden "MCLALjrKGaC6CC4IAfw7AOhe6k0i+EmBAyZmX0tax/W4H2gZLIbsvknfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
end site
license agent max-sessions 9
privilege manage-passwords create
privilege ViewRealTimeReports create
privilege vm-imap create
privilege manage-users create
privilege ViewPrivateList create
privilege local-broadcast create
privilege ViewHistoricalReports create
privilege ManagePublicList create
privilege broadcast create
privilege ManagePrompts create
groupname vmgnp create
groupname Broadcasters create
username kary create
username sandra create
username rose create
username reguerra create
username bety create
username adrianam create
username eri create
username yesika create
username ferdelavega create
username itcolmenero create
username elizabeth create
username luis create
username claudia create
username alehernandez create
username marlene create
username vero create
username eunice create
username vguerra create
username josel create
username rguerrar create
username erika create
username rguerra create
username Administrator create
username Alfredo create
username lucia create
username samuel create
username pilar create
username jorge create
username claudio create
username Agente create
username nadia create
username achampo create
username alejandra create
username rosa create
username isaac create
username eduardo create
username azucena create
username elizabethc create
username liliana create
privilege manage-passwords description "Privilege to reset user passwords"
privilege ViewRealTimeReports description "Privilege to view realtime reports"
privilege vm-imap description "Privilege to manage personal voicemail via IMAP client"
privilege manage-users description "Privilege to create, modify, and delete users and groups"
privilege ViewPrivateList description "Privilege to view private list"
privilege local-broadcast description "Privilege to send local broadcast messages"
privilege ViewHistoricalReports description "Privilege to view historical reports"
privilege ManagePublicList description "Privilege to manage public lists"
privilege broadcast description "Privilege to send local or remote broadcast messages"
privilege ManagePrompts description "Privilege to create, modify, or delete system prompts"
privilege manage-passwords operation system.debug
privilege manage-passwords operation user.pin
privilege manage-passwords operation user.password
privilege ViewRealTimeReports operation report.realtime
privilege vm-imap operation voicemail.imap.user
privilege manage-users operation user.notification
privilege manage-users operation group.configuration
privilege manage-users operation system.debug
privilege manage-users operation user.configuration
privilege manage-users operation user.remote
privilege manage-users operation user.pin
privilege manage-users operation user.password
privilege manage-users operation user.mailbox
privilege ViewPrivateList operation voicemail.lists.private.view
privilege local-broadcast operation broadcast.local
privilege local-broadcast operation system.debug
privilege ViewHistoricalReports operation report.historical.view
privilege ManagePublicList operation system.debug
privilege ManagePublicList operation voicemail.lists.public
privilege broadcast operation broadcast.local
privilege broadcast operation system.debug
privilege broadcast operation broadcast.remote
privilege ManagePrompts operation prompt.modify
privilege ManagePrompts operation system.debug
groupname Administrators member Administrator
groupname Broadcasters privilege broadcast
username kary phonenumber "846"
username sandra phonenumber "840"
username rose phonenumber "830"
username reguerra phonenumber "811"
username bety phonenumber "856"
username adrianam phonenumber "852"
username eri phonenumber "827"
username yesika phonenumber "845"
username ferdelavega phonenumber "815"
username itcolmenero phonenumber "824"
username elizabeth phonenumber "825"
username luis phonenumber "850"
username claudia phonenumber "853"
username alehernandez phonenumber "814"
username marlene phonenumber "855"
username vero phonenumber "854"
username eunice phonenumber "844"
username vguerra phonenumber "812"
username josel phonenumber "819"
username rguerrar phonenumber "833"
username erika phonenumber "822"
username rguerra phonenumber "810"
username Alfredo phonenumber "843"
username lucia phonenumber "829"
username samuel phonenumber "820"
username pilar phonenumber "847"
username jorge phonenumber "837"
username claudio phonenumber "816"
username Agente phonenumber "835"
username nadia phonenumber "849"
username achampo phonenumber "813"
username rosa phonenumber "834"
username isaac phonenumber "848"
username eduardo phonenumber "818"
username azucena phonenumber "838"
username elizabethc phonenumber "839"
username liliana phonenumber "823"
restriction msg-notification create
restriction msg-notification min-digits 1
restriction msg-notification max-digits 30
restriction msg-notification dial-string preference 1 pattern * allowed
backup server url "ftp://127.0.0.1/ftp" credentials hidden "EWlTygcMhYmjazXhE/VNXHCkplVV4KjescbDaLa4fl4WLSPFvv1rWUnfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
calendar biz-schedule systemschedule
closed day 1 from 00:00 to 24:00
open day 2 from 08:00 to 16:00
open day 3 from 00:00 to 24:00
open day 4 from 00:00 to 24:00
open day 5 from 00:00 to 24:00
open day 6 from 00:00 to 24:00
closed day 7 from 00:00 to 24:00
end schedule
calendar holiday date 2016 02 01 description "dia de la constitucion"
calendar holiday date 2016 03 21 description "benito juarez"
ccn application autoattendant aa
description "Cisco Auto-Attendant"
enabled
maxsessions 2
script "aa.aef"
parameter "dialByExtnAnytime" "true"
parameter "busOpenPrompt" "Conmutador_aps_1.wav"
parameter "dialByExtnAnytimeInputLength" "3"
parameter "operExtn" "800"
parameter "welcomePrompt" "Conmutador_aps_3segs_1u.wav"
parameter "disconnectAfterMenu" "false"
parameter "dialByFirstName" "false"
parameter "busClosedPrompt" "AABusinessClosed.wav"
parameter "allowExternalTransfers" "true"
parameter "holidayPrompt" "AAHolidayPrompt.wav"
parameter "businessSchedule" "systemschedule"
parameter "MaxRetry" "0"
end application
ccn application ciscomwiapplication aa
description "ciscomwiapplication"
enabled
maxsessions 10
script "setmwi.aef"
parameter "CallControlGroupID" "0"
parameter "strMWI_OFF_DN" "8001"
parameter "strMWI_ON_DN" "8000"
end application
ccn application msgnotification aa
description "msgnotification"
enabled
maxsessions 10
script "msgnotify.aef"
parameter "logoutUri" "http://localhost/voicemail/vxmlscripts/mbxLogout.jsp"
parameter "DelayBeforeSendDTMF" "1"
end application
ccn application promptmgmt aa
description "promptmgmt"
enabled
maxsessions 1
script "promptmgmt.aef"
parameter "appManagementScript" ""
end application
ccn application voicemail aa
description "Cisco Voicemail"
enabled
maxsessions 1
script "voicebrowser.aef"
parameter "uri" "http://localhost/voicemail/vxmlscripts/login.vxml"
end application
ccn engine
end engine
ccn reporting historical
database local
description "se-172-16-1-2"
end reporting
ccn subsystem sip
gateway address "172.16.1.1"
mwi sip unsolicited
end subsystem
ccn trigger http urlname msgnotifytrg
application "msgnotification"
enabled
maxsessions 0
end trigger
ccn trigger http urlname mwiapp
application "ciscomwiapplication"
enabled
maxsessions 0
end trigger
ccn trigger sip phonenumber 1000
application "voicemail"
enabled
locale "es_MX"
maxsessions 2
end trigger
ccn trigger sip phonenumber 814
enabled
maxsessions 1
end trigger
ccn trigger sip phonenumber 998
enabled
maxsessions 10
end trigger
ccn trigger sip phonenumber 999
application "autoattendant"
enabled
locale "es_MX"
maxsessions 2
end trigger
service phone-authentication
end phone-authentication
service voiceview
enable
end voiceview
voicemail notification enable
voicemail notification preference all
voicemail notification connect-timeout 25
voicemail default mailboxsize 300
voicemail broadcast recording time 300
voicemail default messagesize 240
voicemail notification restriction msg-notification
voicemail operator telephone 1000
voicemail mailbox owner "Alfredo" size 300
description "Alfredo mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "achampo" size 300
description "achampo mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "adrianam" size 600
description "adrianam mailbox"
expiration time 5
end mailbox
voicemail mailbox owner "alehernandez" size 300
description "alehernandez mailbox"
expiration time 10
messagesize 120
end mailbox
voicemail mailbox owner "azucena" size 600
description "azucena mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "bety" size 600
description "bety mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "claudia" size 600
description "claudia mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "claudio" size 300
description "claudio mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "eduardo" size 300
description "eduardo mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "elizabeth" size 300
description "elizabeth mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "elizabethc" size 300
description "elizabethc mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "eri" size 300
description "eri mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "erika" size 300
description "erika mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "eunice" size 300
description "eunice mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "ferdelavega" size 600
description "ferdelavega mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "isaac" size 600
description "vero mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "itcolmenero" size 300
description "itcolmenero mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "jorge" size 600
description "jorge mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "josel" size 300
description "josel mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "kary" size 300
description "kary mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "liliana" size 300
description "liliana mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "lucia" size 300
description "lucia mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "luis" size 600
description "luis mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "marlene" size 600
description "marlene mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "nadia" size 600
description "nadia mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "pilar" size 300
description "pilar mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "reguerra" size 300
description "reguerra mailbox"
expiration time 10
end mailbox
voicemail mailbox owner "rguerra" size 300
description "rguerra mailbox"
end mailbox
voicemail mailbox owner "rguerrar" size 300
description "rguerrar mailbox"
end mailbox
voicemail mailbox owner "rosa" size 300
description "rosa mailbox"
end mailbox
voicemail mailbox owner "rose" size 300
description "rose mailbox"
end mailbox
voicemail mailbox owner "samuel" size 300
description "samuel mailbox"
end mailbox
voicemail mailbox owner "sandra" size 300
description "sandra mailbox"
end mailbox
voicemail mailbox owner "vero" size 300
end mailbox
voicemail mailbox owner "vguerra" size 300
description "vguerra mailbox"
end mailbox
voicemail mailbox owner "yesika" size 300
description "yesika mailbox"
end mailbox
end
06-06-2016 09:37 AM
Thanks , i will check the traces,two things you can try as per other threads.
first try defining max sessions other then 0.
enabled
maxsessions 0>>>>>>>>>>>>
end trigger
Second - try to keep it simple in SIP UA config
mwi-server ipv4:ip unsolicited
06-06-2016 10:34 PM
do the following
1.-trace ccn stacksip dbug
2.- clear trace
3.- mwi refresh telephonenumber 816
4.-the following console commands
CUEGNP# Jun 6 23:35:05 localhost java[2663]: WARNING voicemail MessageWaitingThread setMessageWaiting Got exception java.io.IOException: Server returned HTTP response code: 503 for URL: http://localhost:8080/mwiapp?extn=816&state=1
5.-He left a message on the voicemail
CUEGNP# Jun 6 23:38:52 localhost kernel: Trace Skipped some entries since last read
Jun 6 23:39:13 localhost java: ERROR ccn StackSip DBUG ##### ltp60654-1000, State=DISCONNECTED: ##### [SIP-Local-MT-60655 dn=1000 media=172.16.1.2:21318, mediaStarted=true] ##### [SIP-Remote-MT-60654 dn=5545586137 media=172.16.1.1:29714, mediaStarted=true]: ##### ltp60654-1000, State=DISCONNECTED: ##### [S
Jun 6 23:39:13 localhost ccn: INFO ccn server output String:message=42946:
Jun 6 23:39:15 localhost java[2663]: WARNING voicemail MessageWaitingThread setMessageWaiting Got exception java.io.IOException: Server returned HTTP response code: 503 for URL: http://localhost:8080/mwiapp?extn=816&state=1
attachment debug messages ccsip
ephone-dn need for MWI numbers ??
I do not find a solution to these error messages in the community... =(
06-07-2016 06:43 AM
Have you check config for extension 816 , is MWI enabled on Voice register -DN.
CME config exmaple you provided earlier has a different DN also the traces doesn't have any sip -notify messages.Just try to readd this and test.thanks
mwi-server ipv4:172.16.1.2 unsolicited
07-21-2016 03:27 PM
Hello Deepak Mehta
Sorry, I'm taking up the issue again
I'm starting the resolution again
I summarize the set and done
GATEWAY 2911
TELEPHONES: 7821, 7841
CME: 172.16.1.1
CUE: 172.16.1.2
CME
USER:
voice register dn 8
number 816
allow watch
pickup-group 10
name Claudio Rangel
label 816 Claudio Rangel
mwi
dial-peer voice 1000 voip
description al unity express
destination-pattern 1000
b2bua
session protocol sipv2
session target ipv4:172.16.1.2
dtmf-relay sip-notify
codec g711ulaw
no vad
sip-ua
GNP_GATEWAY#show voice register global
Version 10.0
Mode is cme
Max-pool is 55
Max-dn is 55
Time-format is 24
Time-zone is 9
CUE
CUEGNP# show user detail username claudio
Username: claudio
Full Name: Claudio rangel
First Name: Claudio
Last Name: rangel
Nickname: Claudio rangel
Phone: 816
Phone(E.164):
Fax:
Email:
Epage:
Language: es_MX
GroupMember: <none>
GroupOwner: <none>
Privileges: <none>
CUEGNP# show ccn subsystem sip
Transfer Timeout: 6
SIP RFC Compliance: Pre-RFC3261
Transfer Timeout: 6
CUEGNP# show ccn app
CUEGNP# show ccn application
Script: aa.aef
ID number: 1
Enabled: yes
MaxRetry: 0
operExtn: 800
ID number: 4
Enabled: yes
ID number: 2
Enabled: yes
ID number: 5
Enabled: yes
Script: setmwi.aef
ID number: 3
Enabled: yes
strMWI_OFF_DN: 8001
strMWI_ON_DN: 8000
I keep the following documentation
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unity-express/60081-unity-mwi-problems.html
no trace all
trace ccn stacksip dbug.
mwi refresh
show trace buffer long
CUEGNP# show trace buffer long
Press <CTRL-C> to exit...
11456 07/21 15:48:05.840 ACCN SIPL 0 SIP NewInvitationCallback.invitation()
INVITE sip:1000@172.16.1.2:5060 SIP/2.0
Via: SIP/2.0/UDP 172.16.1.1:5060;branch=z9hG4bK722BF2228;x-route-tag="tgrp:AXTEL"
Max-Forwards: 69
To: <sip:1000@172.16.1.2>
From: <sip:5545586137@172.16.1.1>;tag=8935D068-1FEB
Call-ID: 8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1
CSeq: 101 INVITE
Content-Length: 451
Remote-Party-ID: <sip:5545586137@172.16.1.1>;party=calling;screen=no;privacy=off
Date: Thu, 21 Jul 2016 21:47:31 GMT
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 2407445159-1321406950-2270663624-1320671749
User-Agent: Cisco-SIPGateway/IOS-15.3.3.M6
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Timestamp: 1469137651
Contact: <sip:5545586137@172.16.1.1:5060>
Call-Info: <sip:172.16.1.1:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Diversion: <sip:816@172.16.1.1>;privacy=off;reason=no-answer;counter=1;screen=no
Expires: 180
Allow-Events: telephone-event
Content-Type: multipart/mixed;boundary=uniqueBoundary
MIME-Version: 1.0
--uniqueBoundary
Content-Type: application/sdp
Content-Disposition: session;handling=required
v=0
o=CiscoSystemsSIP-GW-UserAgent 875 8068 IN IP4 172.16.1.1
s=SIP Call
c=IN IP4 172.16.1.1
t=0 0
m=audio 16716 RTP/AVP 0
c=IN IP4 172.16.1.1
a=rtpmap:0 PCMU/8000
a=ptime:20
--uniqueBoundary
Content-Type: application/gtd
Content-Disposition: signal;handling=optional
IAM,
GCI,8f7eb2a74ec311e6875793c84eb7da05
--uniqueBoundary--
11456 07/21 15:48:05.841 ACCN SIPL 0 SIP invitation: targetNumber=1000
11456 07/21 15:48:05.843 ACCN SIPL 0 LocalLine[1000] process invitation, callId=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, globalCallId=null from SIP-Remote-MT-8282 dn=5545586137 addr=172.16.1.1:16716, dtmf=-1, codecs=[0], ptime=20, mediaStarted=false (sip:5545586137@172.16.1.1)
11456 07/21 15:48:05.843 ACCN SIPL 0 LocalLine[1000] InboundCallInfo=SIP-InboundCallInfo: source=5545586137, (sip:5545586137@172.16.1.1), destination=1000, (sip:1000@172.16.1.2), callId=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, gcId=null, lastRedirectDN=816, (sip:816@172.16.1.1), originalCalledDN=816, callingDisplayName=null, arrivalType=no-answer
11456 07/21 15:48:05.843 ACCN SIPL 0 NewInvitationCallback: creating new call
11456 07/21 15:48:05.843 ACCN SIPL 0 SIP-Call-4142:IDLE[] <init>
11456 07/21 15:48:05.843 ACCN SIPL 0 SIP-Provider: getAbstractLine: creating RemoteLineImpl for DN 5545586137
11456 07/21 15:48:05.843 ACCN SIPL 0 RemoteLine[5545586137@172.16.1.1]: created
11456 07/21 15:48:05.843 ACCN SIPL 0 Call.createConnection: this=SIP-Call-4142:IDLE[], line=RemoteLine[5545586137@172.16.1.1], state=ACTIVE, sc=null, mt=[SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=false], addToCall=true
11456 07/21 15:48:05.844 ACCN SIPL 0 [Conn-8283-5545586137] ConnectionState.<init>: state=ACTIVE
11456 07/21 15:48:05.844 ACCN SIPL 0 [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=false] associate with [SIP-Conn-8283, dn=5545586137, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=ACTIVE]
ctrl=[CSTA-SC-8283], MT=[[SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=false]]
11456 07/21 15:48:05.844 ACCN SIPL 0 CallManager.put: callIdImpl=[8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1,null,4142]
11456 07/21 15:48:05.844 ACCN SIPL 0 [Conn-8283-5545586137] <init>: [SIP-Conn-8283, dn=5545586137, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=ACTIVE]
11456 07/21 15:48:05.844 ACCN SIPL 0 SIP-Call-4142:ACTIVE[5545586137:ACTIVE] addCallListener com.cisco.wf.subsystems.callcontrol.AppRoutePointCallListener@6e9b6a
11456 07/21 15:48:05.844 ACCN SIPL 0 Call.createConnection: this=SIP-Call-4142:ACTIVE[5545586137:ACTIVE], line=LocalLine[1000], state=IDLE, sc=ltp8282-1000, State=IDLE: , mt=[SIP-Local-MT-8283 dn=1000 no media], addToCall=true
11456 07/21 15:48:05.844 ACCN SIPL 0 [Conn-8284-1000] ConnectionState.<init>: state=IDLE
11456 07/21 15:48:05.844 ACCN SIPL 0 [SIP-Local-MT-8283 dn=1000 no media] set connection [SIP-Conn-8284, dn=1000, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=IDLE]
ctrl=[ltp8282], MT=[[SIP-Local-MT-8283 dn=1000 no media]]
11456 07/21 15:48:05.844 ACCN SIPL 0 [Conn-8284-1000] <init>: [SIP-Conn-8284, dn=1000, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=IDLE]
11456 07/21 15:48:05.844 ACCN SIPL 0 SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:IDLE] addCallListener com.cisco.wf.subsystems.callcontrol.AppRoutePointCallListener@6e9b6a
11456 07/21 15:48:05.844 ACCN SIPL 0 New InvitationCallback from LocalLine[1000] creates SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:IDLE]
11456 07/21 15:48:05.844 ACCN SIPL 0 NewInvitationCallback.processInvitation: id=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, callId=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, lastRedirectedDN=816, originalCalledDN=816, originalCallingDN=5545586137, calledDN=1000, parentGlobalCallId=null, type=1002, arrivalType=1002
11456 07/21 15:48:05.844 ACCN SIPL 0 LocalLine[1000] process inbound call, gcId=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1
Local: [SIP-Conn-8284, dn=1000, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=IDLE]
ctrl=[ltp8282], MT=[[SIP-Local-MT-8283 dn=1000 no media]] LocalLine[1000]
Remote: [SIP-Conn-8283, dn=5545586137, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=ACTIVE]
ctrl=[CSTA-SC-8283], MT=[[SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=false]] RemoteLine[5545586137@172.16.1.1]
11456 07/21 15:48:05.844 ACCN SIPL 0 [Conn-8284-1000] onCallConnectionOffered: state=IDLE
11456 07/21 15:48:05.844 ACCN SIPL 0 [Conn-8284-1000] setState: IDLE -> OFFERED
11456 07/21 15:48:05.845 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_CONNECTION_OFFERED (1000) call=SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:OFFERED]
EVCall=SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:OFFERED]EVConn=[SIP-Conn-8284, dn=1000, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=OFFERED]
11456 07/21 15:48:05.845 ACCN SIPL 0 SIP-Call-4142, GCID=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1 dispatch to com.cisco.wf.subsystems.callcontrol.AppRoutePointCallListener@6e9b6a
4601 07/21 15:48:05.846 ACCN SIPL 0 SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:OFFERED] addCallListener com.cisco.wf.subsystems.callcontrol.AppCallListener@1ba4b88
4601 07/21 15:48:05.846 ACCN SIPL 0 SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:OFFERED] removeCallListener com.cisco.wf.subsystems.callcontrol.AppRoutePointCallListener@6e9b6a
4601 07/21 15:48:05.849 ACCN SIPL 0 [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=false] - add MediaListener com.cisco.wf.subsystems.callcontrol.AppMediaTerminalListener@1532f8d
4601 07/21 15:48:05.849 ACCN SIPL 0 [SIP-Local-MT-8283 dn=1000 no media] - add MediaListener com.cisco.wf.subsystems.callcontrol.AppMediaTerminalListener@1532f8d
4601 07/21 15:48:05.852 ACCN SIPL 0 ltp8282-1000, State=ALERTED: process Invite, callId=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1
4601 07/21 15:48:05.853 ACCN SIPL 0 ltp8282-1000, State=ALERTED: sending ringing response:
SIP/2.0 180 Ringing
To: <sip:1000@172.16.1.2>;tag=ds131e2f69
CSeq: 101 INVITE
Content-Length: 0
Contact: <sip:1000@172.16.1.2:5060;transport=udp>
Allow: INVITE, BYE, CANCEL, ACK, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: 8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1
4601 07/21 15:48:05.853 ACCN SIPL 0 ltp8282-1000, State=ALERTED: setDialog: com.dynamicsoft.DsLibs.DsSipDialog.DsSipInviteDialog@1487e6b isConfirmed=false
4601 07/21 15:48:05.853 ACCN SIPL 0 [Conn-8284-1000] onCallConnectionRinging: state=OFFERED
4601 07/21 15:48:05.853 ACCN SIPL 0 [Conn-8284-1000] setState: OFFERED -> RINGING
4601 07/21 15:48:05.853 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_CONNECTION_RINGING (1000) call=SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:RINGING]
EVCall=SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:RINGING]EVConn=[SIP-Conn-8284, dn=1000, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=RINGING]
ctrl=[ltp8282], MT=[[SIP-Local-MT-8283 dn=1000 media=172.16.1.2:21426, mediaStarted=false]]
4601 07/21 15:48:05.853 ACCN SIPL 0 SIP-Call-4142, GCID=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1 dispatch to com.cisco.wf.subsystems.callcontrol.AppCallListener@1ba4b88
4037 07/21 15:48:05.862 ACCN SIPL 0 ltp8282-1000, State=ALERTED: sending ok response for dialog
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 127
Call-Info: <sip:172.16.1.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
v=0
o=CUE 3612371 2 IN IP4 172.16.1.2
s=SIP Call
c=IN IP4 172.16.1.2
t=0 0
m=audio 21426 RTP/AVP 0
4037 07/21 15:48:05.862 ACCN SIPL 0 [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=false]: getDtmfMethodOut: sip-notify
4037 07/21 15:48:05.862 ACCN SIPL 0 ltp8282-1000, State=ALERTED: initDtmf: dtmfMethodIn=sip-notify
4037 07/21 15:48:05.862 ACCN SIPL 0 DtmfSubscription.<init>: unsolicited=true
4609 07/21 15:48:05.870 ACCN SIPL 0 ltp8282-1000, State=ALERTED: processAck Call-ID=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1 isReplacing=false, body=null
4609 07/21 15:48:05.870 ACCN SIPL 0 [Conn-8284-1000] onCallConnectionActive: state=RINGING
4609 07/21 15:48:05.870 ACCN SIPL 0 [Conn-8284-1000] setState: RINGING -> ACTIVE
4609 07/21 15:48:05.870 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_CONNECTION_ACTIVE (1000) call=SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:ACTIVE]
EVCall=SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:ACTIVE]EVConn=[SIP-Conn-8284, dn=1000, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=ACTIVE]
, cause=ANSWERED
4609 07/21 15:48:05.870 ACCN SIPL 0 SIP-Call-4142, GCID=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1 dispatch to com.cisco.wf.subsystems.callcontrol.AppCallListener@1ba4b88
4609 07/21 15:48:05.871 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_ANSWERED call=SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:ACTIVE]
CALL_ANSWERED
4609 07/21 15:48:05.871 ACCN SIPL 0 SIP-Call-4142, GCID=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1 dispatch to com.cisco.wf.subsystems.callcontrol.AppCallListener@1ba4b88
4609 07/21 15:48:05.871 ACCN SIPL 0 [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=false]
dispatch media MEDIA_STARTED Event: [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=false] to com.cisco.wf.subsystems.callcontrol.AppMediaTerminalListener@1532f8d
4609 07/21 15:48:05.874 ACCN SIPL 0 [SIP-Local-MT-8283 dn=1000 media=172.16.1.2:21426, mediaStarted=false]
dispatch media MEDIA_STARTED Event: [SIP-Local-MT-8283 dn=1000 media=172.16.1.2:21426, mediaStarted=false] to com.cisco.wf.subsystems.callcontrol.AppMediaTerminalListener@1532f8d
4609 07/21 15:48:27.377 ACCN SIPL 0 ltp8282-1000, State=CONNECTED: processTerminated
BYE sip:1000@172.16.1.2:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.16.1.1:5060;branch=z9hG4bK722C1997;x-route-tag="tgrp:AXTEL"
Max-Forwards: 69
CSeq: 102 BYE
Content-Length: 0
Timestamp: 1469137672
Reason: Q.850;cause=16
P-RTP-Stat: PS=1074,OS=171840,PR=693,OR=110403,PL=0,JI=0,LA=0,DU=21
4609 07/21 15:48:27.377 ACCN SIPL 0 ltp8282-1000, State=CONNECTED: setDisconnected processTerminated, cause=NORMAL
4609 07/21 15:48:27.377 ACCN SIPL 0 SIP-Call-4142:ACTIVE[5545586137:ACTIVE,1000:ACTIVE] clearId=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1
4609 07/21 15:48:27.377 ACCN SIPL 0 ##### ltp8282-1000, State=DISCONNECTED: ##### [SIP-Local-MT-8283 dn=1000 media=172.16.1.2:21426, mediaStarted=true] ##### [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=true]: ##### ltp8282-1000, State=DISCONNECTED: ##### [SIP-Local-MT-8283 dn=1000 media=172.16.1.2:21426, mediaStarted=true] ##### [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=true]
4609 07/21 15:48:27.378 ACCN SIPL 0 [SIP-Local-MT-8283 dn=1000 media=172.16.1.2:21426, mediaStarted=true]
dispatch media MEDIA_STOPPED Event: [SIP-Local-MT-8283 dn=1000 media=172.16.1.2:21426, mediaStarted=true] to com.cisco.wf.subsystems.callcontrol.AppMediaTerminalListener@1532f8d
4609 07/21 15:48:27.378 ACCN SIPL 0 [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=true]
dispatch media MEDIA_STOPPED Event: [SIP-Remote-MT-8282 dn=5545586137 media=172.16.1.1:16716, mediaStarted=true] to com.cisco.wf.subsystems.callcontrol.AppMediaTerminalListener@1532f8d
4609 07/21 15:48:27.378 ACCN SIPL 0 SIP-Call-4142:ACTIVE[5545586137:ACTIVE], remove connection 1000, last=false
4609 07/21 15:48:27.378 ACCN SIPL 0 [Conn-8284-1000] onCallConnectionDisconnected: state=ACTIVE, cause=NORMAL
4609 07/21 15:48:27.378 ACCN SIPL 0 [Conn-8284-1000] setState: ACTIVE -> DISCONNECTED
4609 07/21 15:48:27.378 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_CONNECTION_DISCONNECTED (1000) call=SIP-Call-4142:ACTIVE[5545586137:ACTIVE]
EVCall=SIP-Call-4142:ACTIVE[5545586137:ACTIVE]EVConn=[SIP-Conn-8284, dn=1000, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=DISCONNECTED]
, cause=NORMAL
4609 07/21 15:48:27.378 ACCN SIPL 0 SIP-Call-4142, GCID=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1 dispatch to com.cisco.wf.subsystems.callcontrol.AppCallListener@1ba4b88
4609 07/21 15:48:27.378 ACCN SIPL 0 SIP-Call-4142:ACTIVE[5545586137:ACTIVE] checkCallActive
4609 07/21 15:48:27.378 ACCN SIPL 0 checkCallActive 0: isLocal=false, isMonitored=false
4609 07/21 15:48:27.378 ACCN SIPL 0 SIP-Call-4142:ACTIVE[5545586137:ACTIVE] dropped, connLen=1
4609 07/21 15:48:27.378 ACCN SIPL 0 SIP-Call-4142:ACTIVE[], remove connection 5545586137, last=true
4609 07/21 15:48:27.378 ACCN SIPL 0 SIP-Call-4142:INACTIVE[] change state to inactive, because last connection has been removed
4609 07/21 15:48:27.378 ACCN SIPL 0 [Conn-8283-5545586137] onCallConnectionDisconnected: state=ACTIVE, cause=UNKNOWN
4609 07/21 15:48:27.378 ACCN SIPL 0 [Conn-8283-5545586137] setState: ACTIVE -> DISCONNECTED
4609 07/21 15:48:27.378 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_CONNECTION_DISCONNECTED (5545586137) call=SIP-Call-4142:INACTIVE[]
EVCall=SIP-Call-4142:INACTIVE[]EVConn=[SIP-Conn-8283, dn=5545586137, call=8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1, state=DISCONNECTED]
, cause=UNKNOWN
4609 07/21 15:48:27.378 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_INACTIVE call=SIP-Call-4142:INACTIVE[]
CALL_INACTIVE
EVCall=SIP-Call-4142:INACTIVE[], cause=UNKNOWN
4609 07/21 15:48:27.378 ACCN SIPL 0 Drop NON-monitored SIP-Call-4142:INACTIVE[] because it has zero connections
4609 07/21 15:48:27.378 ACCN SIPL 0 SIP-Call-4142:INACTIVE[] dropped, connLen=0
4609 07/21 15:48:27.378 ACCN SIPL 0 CallManager.removeCall: callIdImpl=[8F7F4ECF-4EC311E6-875B93C8-4EB7DA05@172.16.1.1,null,4142]
4609 07/21 15:48:27.378 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_DROPPED call=SIP-Call-4142:INVALID[]
CALL_DROPPED
EVCall=SIP-Call-4142:INVALID[], cause=UNKNOWN
4609 07/21 15:48:27.378 ACCN SIPL 0 SIP-Call-4142:INVALID[] checkCallActive
4609 07/21 15:48:27.379 ACCN SIPL 0 ltp8282-1000, State=DISCONNECTED: Drop Call because mode= SIP
6235 07/21 15:48:27.386 ACCN SIPL 0 SIP-Call-4142:INVALID[] removeCallListener com.cisco.wf.subsystems.callcontrol.AppCallListener@1ba4b88
CUEGNP#
This is mandatory ??
ephone-dn 44
number 8000...
mwi on
ephone-dn 45
number 8001...
mwi off
I have not configured it to be SIP phones
I need some configuration ??
which is my mistake ??
07-21-2016 03:53 PM
You don't need
07-21-2016 04:32 PM
Configured as follows
voice register dn 8
number 816
allow watch
pickup-group 10
name Claudio Rangel
mwi
voice register pool 8
lpcor type local
lpcor incoming end-user
busy-trigger-per-button 2
id mac DCEB.94CE.84B3
type 7841
number 1 dn 8
cor incoming Nivel11 default
presence call-list
username 8 password 37245
description 7841
codec g711ulaw
speed-dial 1 9018181039820 label "Enlace"
speed-dial 2 9018002884638 label "Alestra"
conference add-mode creator
conference admin
Reviewing the documentation my log is something different than what comes in the documentation
Example: I do not see the cancellation message
SIP/2.0 180 Ringing Via: SIP/2.0/UDP 14.80.227.145:5060 From: "Cisco SIP Channel3" <sip:outbound-0@14.80.227.125>;tag=f0a4ab8e-488 To: <sip:1109811043@14.80.227.125;user=phone>;tag=5FF5244-43A Date: Sat, 15 Jun 2002 13:33:41 GMT Call-ID: a1c0ece2-486@14.80.227.145:5060 Server: Cisco-SIPGateway/IOS-12.x CSeq: 51 INVITE Allow: UPDATE Allow-Events: telephone-event Contact: <sip:1109811043@14.80.227.125:5060> Content-Length: 0 2072 07/14 14:28:27.294 ACCN SIPL 0 ignore null remote tag for Dialog1610: callid= a1c0ece2-486@14.80.227.145:5060, localTag=f0a4ab8e-488, remoteTag=5FF5244-43A 2072 07/14 14:28:27.294 ACCN SIPL 0 ltp95: ContactingState processResponse 100 Trying 2072 07/14 14:28:27.294 ACCN SIPL 0 ignore null remote tag for Dialog1611: callid= a1c0ece2-486@14.80.227.145:5060, localTag=f0a4ab8e-488, remoteTag=5FF5244-43A 2072 07/14 14:28:27.294 ACCN SIPL 0 ltp95: ContactingState processResponse 180 Ringing 2106 07/14 14:28:32.274 ACCN SIPL 0 ltp95: ContactingState close terminate cause=20 2106 07/14 14:28:32.275 ACCN SIPL 0 addHeadersAndBody: branch = null 2106 07/14 14:28:32.276 ACCN SIPL 0 --- send message --- to 14.80.227.125:5060 CANCEL sip:1109811043@14.80.227.125;user=phone SIP/2.0 Via: SIP/2.0/UDP 14.80.227.145:5060
My log
I do not see the numbers 8000 and 8001
Annex log
SIP/2.0 180 Ringing
Via: SIP/2.0/UDP 172.16.1.1:5060;branch=z9hG4bK722D3B9C;x-route-tag="tgrp:AXTEL"
To: <sip:1000@172.16.1.2>;tag=dsd2d3ed5d
Call-ID: 461AB050-4ECF11E6-87CE93C8-4EB7DA05@172.16.1.1
CSeq: 101 INVITE
Content-Length: 0
Cisco-Gcid: 461AB050-4ECF11E6-87CE93C8-4EB7DA05@172.16.1.1
12669 07/21 17:11:55.141 ACCN SIPL 0 ltp8284-1000, State=ALERTED: setDialog: com.dynamicsoft.DsLibs.DsSipDialog.DsSipInviteDialog@823f2a isConfirmed=false
12669 07/21 17:11:55.141 ACCN SIPL 0 [Conn-8286-1000] onCallConnectionRinging: state=OFFERED
12669 07/21 17:11:55.141 ACCN SIPL 0 [Conn-8286-1000] setState: OFFERED -> RINGING
12669 07/21 17:11:55.141 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_CONNECTION_RINGING (1000) call=SIP-Call-4143:ACTIVE[5545586137:ACTIVE,1000:RINGING]
EVCall=SIP-Call-4143:ACTIVE[5545586137:ACTIVE,1000:RINGING]EVConn=[SIP-Conn-8286, dn=1000, call=461AB050-4ECF11E6-87CE93C8-4EB7DA05@172.16.1.1, state=RINGING]
ctrl=[ltp8284], MT=[[SIP-Local-MT-8285 dn=1000 media=172.16.1.2:21016, mediaStarted=false]]
12669 07/21 17:11:55.142 ACCN SIPL 0 SIP-Call-4143, GCID=461AB050-4ECF11E6-87CE93C8-4EB7DA05@172.16.1.1 dispatch to com.cisco.wf.subsystems.callcontrol.AppCallListener@131f97f
4039 07/21 17:11:55.150 ACCN SIPL 0 ltp8284-1000, State=ALERTED: sending ok response for dialog
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 127
