my phones unable to call each other internally.what 's missing in my configuration? please help me
cameroun
hi everyone!
I did not really know in TOIP . Can someone look at my configuration attached and tell me what 's missing?
For now , I'm just at the stage where my phones must call each other internally.
That is to say, the user who has the number 100 , should be able to call the one with the number 101 .
My phones are recorded correctly, there has intonnation , but they do not casually refer to them internally
please what is wrong with my setup ?
CME: cisco 3925
ip phone types: 7841 and 9971
here is the status of the message that appears on the IP phone: File Not Found: Ringlist-wb.xml
6 Replies 6
aseanand89
Do  you mean the phones are registered but they are not able to call each other?
Send us the output of the following:
Show voice register all
show voice register dial-peers
Aseanan, thank you for you help in advance.
In attached file the Show voice output:
Kind regards
Sreekanth Narayanan
Along with the outputs below can you also send the following debugs?
debug ccsip message
debug voip ccapi inout
Before you enable the debugs, please do the following
service sequence
no logging console
no logging rate
logging buffered 1000000
Then enable the debugs and try to do the call.
Hi, Sreekanth,
Thank you for your Help,
Nothing happens when I order these tapes and when I initiate a call.
i've somes errors messages on my 9971:
Error Updating Local
File Not Found: United_States/g4-tones.xml
Upgrade Reject: HW comptat faillure. Must use 9.3(2) or later release on this phone
VPN Error: VPN is not Configured.
No trust List installed
Updating Trust List
CUCM closed TCP connection
Is this that prevents calls ? I can not find the firmware
Kind regards
The output you sent indicates that the phones are registered fine.
Can you check the firmware currently running on the phone? Is it 9-3-2?
Press the Applications button >>> select Phone Information >>>> Active Load
Also, do the following:
1. Enable the following debugs:
debug ccsip messages
debug voice ccapi inout
2. Run the following commands:
Conf t
no logging console
logging monitor
exit
term monitor
3. Make a call from an IP Phone and check if debug appears. Alternatively you may try sh log to check if any debugs were collected.
Tagir Temirgaliyev
voice register global
 no dialplan-pattern 1 0... extension-length 3
 create profile
