Need help for configuring Direct dial
roopesh.n
Hi All,
In my office i need to configure a direct dial fecilty to one of our extesion in side office. We are using CCM 4.0 .And mgcp gateway
Eg; Our extension is 222 so peaple who are calling from out side they shuld be able to conect to to our extension directly with out any transfer of calls.
Please help me to find a solution
27 Replies 27
Roopesh,
Which port is the PSTN coonecting to on your router.
Is is connecting on the old or new router
The new router seems to be mixed MGCP and H323
Can you please supply the info
Alex
Regards, Alex. Please rate useful posts.
Hi Alex,
We are not using the old router.That we already removed from the network.
PSTN coonecting to on your new router.port voice-port 3/0.
Roopesh
Roopesh,
Voive port 3/0:15
This is an ISDN PRI E1 , this is NOT MGCP controlled.
The elements of config which affect this port are :-
controller E1 3/0
framing NO-CRC4
clock source internal
pri-group timeslots 1-31
description For Incoming
interface Serial3/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
voice-port 3/0:15
connection plar 500
num-exp 8025053... ...
The line I have highlighted in bold is forcing all incomming calls to be sent to Extn DN 500
Please try adding the follwing lines to your config:-
voice-port 3/0:15
no connection plar 500
Also check the "INCOMING CALLS " section of your CCM Gateway page for this H323 Gateway and ensure that the CSS contains the partitions that your phones exist on.
Let me know if this helped
Alex
Hi Alex,
The PRI line is conected to controller E1 3/0 in our new router.
And  if diled 25053500 it will go to our office reception  phone .
Same like we need to be able to call 25053222 our extension Iam looking for this only .I thing we are getting closer to our aim.
Thankas
Roopesh
Roopesh,
Can you run
debug isdn q931
Make a call and post the output to the blog
Alex
Hi Alex
Please find the log
oh-rt2#debug isdn q931
debug isdn q931 isON.
oh-rt2#sh dubugging
The following ISDN debugs are enabled on all DSLs:
debug isdn error isON.
Roopesh
Hi Roopesh,
If you are access the router via telnet you need to also run the
"term mon" command
Make the calll inbound and copy and paste the debug output to this blog.
Once you obtain the debug
run these 2 command
undebug all
term no mon
regards
Alex
Hi Alex,
Please find the logs
oh-rt2#en  term mon
*Mar  7 22:04:13: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediately
*Mar  7 22:04:17: ISDN Se4/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0728
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0181, '125'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x80, '8970325670'
Plan:Unknown, Type:Unknown
*Mar  7 22:04:17: ISDN Se4/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x8728
*Mar  7 22:04:18: ISDN Se4/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8728
*Mar  7 22:04:24: ISDN Se4/0:15 Q931: RX <- ALERTING pd = 8  callref = 0x8728
Progress Ind i = 0x8488 - In-band info or appropriate now available
*Mar  7 22:04:35: ISDN Se4/0:15 Q931: RX <- CONNECT pd = 8  callref = 0x8728
Date/Time i = 0x0B0A0C1419
*Mar  7 22:04:35: %ISDN-6-CONNECT: Interface Serial4/0:30 is now connected to 8970325670 N/A
*Mar  7 22:04:35: ISDN Se4/0:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0728
*Mar  7 22:04:43: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediately
*Mar  7 22:05:13: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediately
*Mar  7 22:05:33: %ISDN-6-DISCONNECT: Interface Serial4/0:30  disconnected from 8970325670 , call lasted 57 seconds
*Mar  7 22:05:33: ISDN Se4/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x0728
Cause i = 0x8090 - Normal call clearing
*Mar  7 22:05:33: ISDN Se4/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x8728
*Mar  7 22:05:33: ISDN Se4/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0728
*Mar  7 22:05:43: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediately
% Type "show ?" for a list of subcommands
oh-rt2#sh debug isdn q931
*Mar  7 22:06:13: %PS-3-MULTFAIL: There is more than one failure with the  Power System 1; please resolve problems immediatelyterm mon       en
oh-rt2#ensh debug isdn q931term mon       en      term mondebug isdn q931sh             en   ensh debugging
oh-rt2#
Roopesh
Roopesh,
From this trace
You are receiving a SETUP for channel 31
You are not receiving any called or calling number information from the service provider.
That explains why you had a PLAR 500 set on the voice port.
You need to ask the service provider to send you the dialling info.
Alex
Hi Alex,
But if we diled 25053500 we are able to conect to Reception.
As like this if i add  "Connection PLAR 222"  on the voice port. it wiil work or  not
Roopesh
Roopesh
Yes it should work
But all incoming calls on this PRI are then going to call 222
Alex
HI Alex ,
Thanks very much for the help,
I will check with Service provider fro this
Can i have your Number Alex .
Roopesh
Hi Alex,
I have checked with our Service provider .And i haven't got a clear answer.
But if we diled 25053500 or 25053600 or 25053700 all these number are going to Reception(extension 100) , May i know how it hapening if we dont have that fecility from our service provider
Roopesh
