Showing results forĀ
Search instead forĀ
Did you mean:Ā
Need help understanding WFQ
Velimir Filipov
Dear folks,
I am currently trying to deeply understand Weighted fair queuing (WFQ), how exactly it schedules packets for the outgoing hardware queue.
As far as I understand, the queueing in each queue is done in such way:
Packet  enters the queue corresponding to its flow (based on  src-dst-ip-port-prec). It gets a sequence number, which equals to the  weight * packetsize + previous packet in the queue if any. When the  outgoing interface is ready to transmit, scheduler picks the packet with  lowest sequence number amongst all the queues.
Let's consider the following scenario. We have 3 tcp flows having same precedence - lets say 0.
Queue1 is FTP - big packets of 1500 byte size.
Queue2 is Telnet - small packets of lets say 100 byte size.
Queue3 is another Telnet - small packets of lets say 100 byte size.
All  flows build up separate queue. Since all flows got same precedence,  lets calculate the weight as 1, for easier computations. So seq equals  to size + prevous packet in queue if any.
Ok let's say one packet arrive in each of the queues.
Queue1:   1500
SEQ        (1500)
Queue2:   100
SEQ        (100)
Queue3:   100
SEQ        (100)
I  think it would go for a random decision to select one of the packets  with same sequence value. Lets say it picks the packet in Queue2. Ok now  Queue2 is empty.
Queue1:   1500
SEQ        (1500)
Queue2:
SEQ
Queue3:   100
SEQ        (100)
Then  after the packet that was taken from Queue2 is transmited, it schedule  the 100 byte packet in Queue3 for transmission as it has lower seq  number, but imagine that during that transmission, new packet arrive in  Queue2. As the queue is empty at that moment, the new packet gets seq of  100.
Queue1:   1500
SEQ        (1500)
Queue2:   100
SEQ        (100)
Queue3:
SEQ
Then  it schedule the 100 byte packet in Queue2 for transmission, and during  that new packet in Queue3 arrive, and that process keeps repeating.
Considering that scenario, it seems that the packet in Queue1 might never be transmited.
So my questions are:
1)  Am I understanding the algorithm correctly as I have read many  contraversary opinions and can this situation actually happen, when  lower size packets totally starve the big size ones.
2)  Also considering having multiple high precedence flows, each of them  probably emptying its own queue at some point, and while other high prec  flows gets transmited, it fills up the queue again and etc, would they  totally starve low precedence traffic ?
Also  as the maximum number of dynamic flows is limited to 4096 (default is  256 I think), at some point different flows might end up in a single  queue.
Lets  say 2 flows enter same queue, but one is having precedence 7 and the  other one 0. Considering the fact that each queue is acting as FIFO,  that would mean that the flow with precedence of 7 actually won't be  prioritised over the one with prec of 0 (guess enabling WRED would  workaround that).
3)  Will two flows eventually end up in a single  FIFO queue and get served in a FIFO way no matter their precedence ?
Can someone explain how exactly WFQ works ?
Thank you for reading and I am hoping that I can finally understand how this WFQ actually works.
Looking forward for your opinions.
Best regards.
Velimir Filipov
anyone ?
Duplicate post.
Yea, I know. I am sorry about it, but since no one replied in the Routing and Switching category, I decided to post it on VOIP section as well, because QoS is more related to that.
Please moderators, delete one of the threads by your opinion.
Best regards.
