IP Telephony and Phones
Labels
                   Hi, I have CME 8.6 which works fine for outgoing/incoming calls to/from PSTN by means of sip trunk, also is posible to call to other CME in remote site via h323 trunk.The only problem is with AVAYA  h323 trunk, I can call from CME ...
                   I just finished configuring remote SSL VPN phones using a 7945G. I have an ASA 5510 as the firewall and 2800 Series router running Call Manager Express 8.6. I followed the following guide at the below link almost line for line (obv...
I would like to do the following:   User dials 1-800-xxx-xxxx.  Actual called number is 216-xxx-xxxx.  This is transparent to the user who called 1-800-xxx-xxxx (i.e.Cisco IP phone display = 1-800-xxx-xxxx).  The reason for this is that there is a co...
