02-24-2020 05:40 AM
Hi all,
I need help with a wireless IPPhone 8821 to connect/register it to a cloud SIP server. The firmware on the phone is : cmterm-8821.11-0-5SR2-2
I let you my SEP[MAC].cnf.xml file en attachment.
Thanks for your help !
Solved! Go to Solution.
02-25-2020 06:53 AM
I found my issue,
The transportLayerProtocol was set to 1, where some website tell it's for UDP but in fact UDP is 2. So after changing this value everything is working.
Thanks !
02-24-2020 01:42 PM
02-25-2020 06:53 AM
I found my issue,
Thanks !
02-27-2020 11:11 AM
Hi, I got the 8821 working, but there is no hold or transfer. Can someone explain how that works? Thanks.
11-26-2021 01:15 PM
Hi there,
Did you manage to get the hold and transfer functions working with Asterisk and the Cisco 8821 cordless handset?
