02-08-2013 01:16 PM - edited 03-16-2019 03:36 PM
Ive searched through here but can only find answers to the opposite of what I want to happen. Here is the scenrio.
We have a lobby phone, it has restricted access - thats all good. On top of the restrictions they are wanting me to make it so when this phone dials an internal extension it does not display the name of the person they are calling, just the number. I can restrict it so that the person being called does not see the information of the calling party but trying to do it the other way seems as though I would need a ton of translation patterns etc to accomplish this. So again,
Phone A calls phone B.
Phone A sees nothing but the number of phone B on the screen. No name information.
Thanks!
Solved! Go to Solution.
02-08-2013 01:30 PM
Hi Tracy
Basically what you can do is this... let's say you have a phone with a CSS of 'National'.
Create a new Partition, in that put a translation pattern that matches !, has a CSS of 'National' (i.e. the phone CSS) and no called/calling party mods,except:
Connected Line ID Presentation - Restricted
Connected Name Presentation - Restricted
Then assign that CSS to the phone. Basically routing through that trans pattern should hide the connected info, then route through the 'national' CSS or whatever you have.
Aaron
02-08-2013 01:30 PM
Hi Tracy
Aaron
02-11-2013 08:05 AM
Thanks, Aaron!
02-08-2013 01:30 PM
dear Find the below , if i understand true . You need to Calling name should be sent from.
dial-peer voice 902 pots
description == International ==
destination-pattern 9011T
port 0/0/0:23
prefix 011
clid strip name
02-11-2013 08:06 AM
Thank you as well islam. I didnt need the info for the gateway but thank you nonetheless! That is good to know too.
