Negotiated Codec : No Codec (0 bytes) Audio one way
christianbernal
Good day team
I have a question, I have the next topology CME ---> PSTN (SIP)
the problem is when I realized a call to PSTN, only have one way audio, and the command "show sip calls" show the next information:
Call 3
SIP Call ID                : D2BDE21C-896211E8-80D0D483-61BE0435@192.168.150.2
   State of the call       : STATE_RECD_PROCEEDING (4)
   Substate of the call    : SUBSTATE_PROCEEDING_PROCEEDING (2)
   Calling Number          : 2091
   Called Number           : 7850710
   Bit Flags               : 0x400018 0x200100 0x200
   CC Call ID              : 156
   Source IP Address (Sig ): 192.168.150.2
   Destn SIP Req Addr:Port : [10.8.88.81]:5060
   Destn SIP Resp Addr:Port: [10.8.88.81]:5060
   Destination Name        : 10.8.88.81
   Number of Media Streams : 1
   Number of Active Streams: 1
   RTP Fork Object         : 0x0
   Media Mode              : flow-through
   Media Stream 1
     State of the stream      : STREAM_ACTIVE
     Stream Call ID           : 156
     Stream Type              : voice+dtmf (1)
     Stream Media Addr Type   : 1
     Codec Payload Type       : 255 (None)
     Negotiated Dtmf-relay    : inband-voice
     Dtmf-relay Payload Type  : 0
     QoS ID                   : -1
     Local QoS Strength       : BestEffort
     Negotiated QoS Strength  : BestEffort
     Negotiated QoS Direction : None
     Local QoS Status         : None
     Media Source IP Addr:Port: [192.168.150.2]:18154
This is the most important configuration:
voice class codec 2
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729r8
dspfarm profile 2 transcode
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 maximum sessions 20
 associate application SCCP
dial-peer voice 1040 voip
 description LOCAL
 translation-profile outgoing 4
 preference 1
 destination-pattern 7850710
 session protocol sipv2
 session target ipv4:10.8.88.81
 voice-class codec 2
 voice-class sip bind media source-interface Vlan3
 dtmf-relay rtp-nte
Thank You for your time .... Attach the full sh run
0 Replies 0
