Newly Created Voicemail Mailbox-fastbusy
tmccabe
Another IP Communicator issue. When I create users that have only the IP Communicator software phone and I create a 7.15 Unity VM mailbox for them, callers get a  fast busy when dialing either their extension or their DID unless they have IP Comm up and on.
I have compared their settings to mine and I cant see why that would be. The only difference is that I have both the IP Comm setup and a 7942 hard phone.
11 Replies 11
Jaime Valencia
Do you have configured CFUR to VM??
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
huh ?
Rob Huffman
Hi there,
Just to add to Java's reference (+5 Java-Man!)
CFUR = Call Forward Unregistered (set under the DN config page
Cheers!
Rob
I put a snip of a screen shot from my setup - not sure which is supposed to be checked. The difference is I have both IP Comm for home on my desktop at home and I have a hard phone 7942. The setting I am after is for those users that just have the software IP Comm on their laptop.
For the peeps that only have IPC set both the Internal/External checkboxes
to VM and you should be good to go.
Cheers!
Rob
Thanks Robert - do you work for a company that has Cisco Telephony that you admin or are you with a Cisco service provider ?
I work at Mount Royal University in Calgary
Cheers!
Rob
Cool ! How many phone sets there ? A ton I bet !!
Im over in the N.E. by Devry - we do tax consulting and we only have 160 phones - going to upgrade in July to 8.5 - Im still a newbie at this stuff.
Rob Huffman
Hi there,
We are @ about 3,000 sets
There's always lots to learn for all of us so don't feel alone here. That's
what makes the CSC such a great resource and fantastic community!
Cheers!
Rob
