NME-CUSP-522 is unable to load the image
serg_shipaev
Hi!
During the installation of  the subject, I've got the following issue:
DDR2 Memory 2047 MB with ECC detected
Intel(R) Pentium(R) M processor 1.40GHz
BIOS ISE 6.00, Build date: 08/02/06
System Now Booting ...
<sniped>
Booting from secondary boot loader..., please wait.
[BOOT-ASM]
Please enter '***' to change boot configuration:
Unable to load image
Unable to boot image�
After the output above, the module is reloading (in a cycle).
Any ideas? I suppose there no CUSP image file is on the HDD. Or HDD is broken. Has anyone experienced the same problem?
wbr,
Serg
jhitt-limited
Level 4
Level 4
I am experiencing this problem after a power outage.  How did you get past it?
As I remember, I just booted the system via tftp using helper file. Then I did the clean install.
