No Audio
Earl ITinit
Hi!
We recently started having issues with no audio for external inbound and outbound calls.
A heads up I'm not that experienced with troubleshooting these kinds of issues so sorry if I don't understand how things work fully. I'm trying my luck here before we contact ask TAC.
Before this no audio issue we had an issue that some calls were dropped after 15 minutes. We "hopefully" did a workaround for that problem(no reports of that issue yet) when we sat the cube sessions expire timer to max. Couple of days later we are getting reports of no audio on calls.
We got an idea that the sessions are hanging due to the timer and that's why we don't get audio.
Call flow SIP phone <--> CUCM <--> CUBE <--> ITSP
Going to add a SIP trace from RTMT as an attachement soon.
This case the person tested it on his own phone. First couple of calls everything worked as it should. After the 3th or 4th call no audio.
Here is the first invite from SIP phone to CUCM. Calling 20224 Called 092888888
SENDER: [SEPCC70ED350FC4] 10.140.7.2
GUID: cc70ed35-0fc4001e-7c320351-5a43ad0e@10.140.7.2
MSG_LABEL: INVITE
RECEIVER: 10.20.200.3
MAC_ADDRESS: SEPCC70ED350FC4
MSGTAG: 124316808
MSG_TYPE: UCM_CTRACE
CORRELATIONID: 4,100,14,159790.4980^10.140.7.2^*
TIMESTAMP: 2021/01/13 14:47:44.015
Detailed Sip Message
INVITE sip:092888888@SS-20-0004;user=phone SIP/2.0
Via: SIP/2.0/TCP 10.140.7.2:50141;branch=z9hG4bK675f8940
From: " Name Of Caller" < sip:20224@SS-20-0004> ;tag=cc70ed350fc4121f26009557-77720333
To: < sip:092888888@SS-20-0004>
Call-ID: cc70ed35-0fc4001e-7c320351-5a43ad0e@10.140.7.2
Max-Forwards: 70
Session-ID: 03c3922100105000a000cc70ed350fc4;remote=00000000000000000000000000000000
Date: Wed, 13 Jan 2021 13:47:38 GMT
CSeq: 101 INVITE
User-Agent: Cisco-CP8851/12.8.1
Contact: < sip:34834717-8812-c239-40d0-e5b396173679@10.140.7.2:50141;transport=tcp> ;+u.sip!devicename.ccm.cisco.com=" SEPCC70ED350FC4"
Expires: 180
Accept: application/sdp
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: " Name of caller" < sip:20224@SS-20-0004> ;party=calling;id-type=subscriber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-8.5.1
Allow-Events: kpml,dialog
Recv-Info: conference
Recv-Info: x-cisco-conference
Content-Length: 711
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 8691 0 IN IP4 10.140.7.2
s=SIP Call
b=AS:4064
t=0 0
m=audio 25096 RTP/AVP 114 9 124 113 115 0 8 116 18 101
c=IN IP4 10.140.7.2
b=TIAS:64000
a=rtpmap:114 opus/48000/2
a=fmtp:114 maxplaybackrate=16000;sprop-maxcapturerate=16000;maxaveragebitrate=64000;stereo=0;sprop-stereo=0;usedtx=0
a=rtpmap:9 G722/8000
a=rtpmap:124 ISAC/16000
a=rtpmap:113 AMR-WB/16000
a=fmtp:113 octet-align=0;mode-change-capability=2
a=rtpmap:115 AMR-WB/16000
a=fmtp:115 octet-align=1;mode-change-capability=2
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
Appreciate any help I can get!
Thank you.
Earl
6 Replies 6
Can you describe the call flow? Cme or cucm? Voice gateway how its
connected to cucm? PSTN is it PRI or SIP?
****** please remember to rate useful posts
SIP phone --> subscriber / CUCM ---> CUBE ---> ITSP
Cisco 8851        10.20.200.3            10.33.120.152
10.140.7.2
20224
I believe its SIP yes.
Ok, during the silent call, on CUBE use 'show call active voice bri' and
identify both calls legs of the call using calling/called numbers. Check
the tx/rx stats on each call leg by repeating the show command and see
which ones and changing and which are not to see where is the problem.
FYI, tx on called leg transmitted from CUBE while rx on called leg received
by CUBE
Same for calling leg.
Not sure if its much to see or if its very hard for me to find that call since we have at least 100+ active almost all the time, but the tx/rx stats shows 0/0 from default.
I'll give it a try though
The issue has been somewhat solved. Seems like my colleague contacted TAC and they were able to solve / work around the issue.
I do thank you for your help!
For the greater good of the community it would be nice of you if you could add a little information on what was done to solve this.
Response Signature
