no caller-id on mgcp with FXO ports
abd88elhak
hi
i'm using cucm 10.5 with cisco router version 15.0 as MGCP gateway
i'm facing a problem with fxo ports :no caller-id displayed even this option is enabled on cucm
regdas
6 Replies 6
abd88elhak
any hepl for this issue ????
hi
all incoming call via FXO pots display unknown caller id
the option caller id is enabled
Try below :-
Go to the voice-port and run below command
timing guard-out 1000
- Do a shut no shut for the port
Make a test call and collect the below debugs. Provide the calling and called number as well.
debug voice ccapi inout
Debug vpm signal
Debug voip vtsp all
debug mgcp packets
Also get the Show tech from the gateway.
Abhay Reyal
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
hi i have same problem and i did what u said then its unknown number again for the incoming calls
keep in ur mind that im using Vodafone sim card because mi dont have in my place landline infra ,so im using sim card installed inside primacell device and connected to FXO voice port  . vodafone card i thinkits already has CLID OPTION (telecommunications copmany)
amr alrazzaz
amr alrazzaz
Share the exact call flow ? Is it for incoming or outbound call ?
Abhay Reyal
Abhay Singh Reyal
