TIB-SMR-CME-RTR#show dialplan number 90653927884
Macro Exp.: 90653927884
VoiceOverIpPeer900
peer type = voice, system default peer = FALSE, information type = voice,
description = `VOIP.CALLS.TO.TIB-TPA',
tag = 900, destination-pattern = `[9]..',
voice reg type = 0, corresponding tag = 0,
allow watch = FALSE
answer-address = `', preference=0,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
rtp-ssrc mux = system
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 900, Admin state is up, Operation state is up,
incoming called-number = `',
connections/maximum = 0/unlimited,
bandwidth/maximum = 0/unlimited,
DTMF Relay = enabled,
modem transport = system,
URI classes:
Incoming (Request) =
Incoming (Via) =
Incoming (To) =
Incoming (From) =
Destination (Diversion) =
Destination (From) =
Destination (Referred-By) =
Destination (To) =
Destination (Via) =
Destination =
Destination route-string = None
huntstop = disabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
outgoing LPCOR:
Translation profile (Incoming):
Translation profile (Outgoing):
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
mailbox selection policy: none
type = voip, session-target = `ipv4:192.168.4.3',
technology prefix:
settle-call = disabled
ip media DSCP = ef, ip media rsvp-pass DSCP = ef
ip media rsvp-fail DSCP = ef, ip signaling DSCP = af31,
ip video rsvp-none DSCP = af41,ip video rsvp-pass DSCP = af41
ip video rsvp-fail DSCP = af41,
ip defending Priority = 0, ip preemption priority = 0
ip policy locator voice:
ip policy locator video:
UDP checksum = disabled,
IPv6 UDP checksum = disabled
session-protocol = sipv2, session-transport = system,
req-qos = best-effort, acc-qos = best-effort,
req-qos video = best-effort, acc-qos video = best-effort,
req-qos audio def bandwidth = 64, req-qos audio max bandwidth = 0,
req-qos video def bandwidth = 384, req-qos video max bandwidth = 0,
dtmf-relay = rtp-nte,
RTP dynamic payload type values: NTE = 101
Cisco: NSE=100, fax=96, fax-ack=97, dtmf=121, fax-relay=122
CAS=123, TTY=119, ClearChan=125, PCM switch over u-law=0,
A-law=8, GSMAMR-NB=117 iLBC=116, AAC-ld=114, iSAC=124
MP4A-LATM=111, lmr_tone=0, nte_tone=0
h263+=118, h264=119
G726r16 using static payload
G726r24 using static payload
RTP comfort noise payload type = 19
fax rate = voice, payload size = 20 bytes
fax protocol = pass-through
fax-relay ecm enable
Fax Relay ans treatment disabled
Fax Relay ans enabled
Fax Relay SG3-to-G3 Enabled (by system configuration)
fax NSF = 0xAD0051 (default)
voice-class codec = 1
codec = g729r8, payload size = 20 bytes,
video codec = None
voice class codec = 1
voice class sip session refresh system
voice class sip rsvp-fail-policy voice post-alert mandatory keep-alive interval 30
voice class sip rsvp-fail-policy voice post-alert optional keep-alive interval 30
voice class sip rsvp-fail-policy video post-alert mandatory keep-alive interval 30
voice class sip rsvp-fail-policy video post-alert optional keep-alive interval 30
text relay = disabled
Media Setting = forking (disabled) flow-through (global)stats-disconnect (disabled)
Expect factor = 10, Icpif = 20,
Playout Mode is set to adaptive,
Initial 60 ms, Max 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Fax nominal 300 ms
Max Redirects = 1, signaling-type = cas,
VAD = disabled, Poor QOV Trap = disabled,
Source Interface = NONE
voice class sip url = system,
voice class sip tel-config = system,
voice class sip rel1xx = system,
tvoice class sip outbound-proxy = system,
voice class sip asserted-id = system,
voice class sip privacy = system,
voice class sip e911 = system,
voice class sip history-info = system,
voice class sip pass-thru headers = system,
voice class sip pass-thru subscribe-notify-events = system,
voice class sip pass-thru content unsupp = system,
voice class sip pass-thru content sdp = system,
voice class sip copy-list = system,
voice class sip anat = system,
voice class sip g729 annexb-all = system,
voice class sip early-offer forced = system,
voice class sip negotiate cisco = system,
voice class sip reset timer expires 183 = system,
voice class sip block 180 = system,
voice class sip block 181 = system,
voice class sip block 183 = system,
voice class sip preloaded-route = system,
voice class sip random-contact = system,
voice class sip random-request-uri validate = system,
voice class sip call-route p-called-party-id = system,
voice class sip call-route history-info = system,
voice class sip call-route url = system,
voice class sip privacy-policy send-always = system,
voice class sip privacy-policy passthru = system,
voice class sip privacy-policy strip history-info = system,
voice class sip privacy-policy strip diversion = system,
voice class sip bandwidth audio = system,
voice class sip bandwidth video = system,
voice class sip error-code-override options-keepalive failure = system,
voice class sip error-code-override call spike failure = system,
voice class sip error-code-override cac-bandwidth failure = system,
voice class sip encap clear-channel = system,
voice class sip send 180 sdp = system,
voice class sip map resp-code 181 = system,
voice class sip bind control = system,
voice class sip bind media = system,
voice class sip registration passthrough = System
voice class sip nat mode = System
voice class sip conn reuse = System
voice class sip authenticate redirecting-number = system,
voice class sip referto-passing = system,
voice class sip extension = system,
voice class sip contact-passing = system,
voice class sip requri-passing = system,
voice class sip content sdp version increment = system,
voice class phone proxy name: None
voice class phone proxy config: N/A
redirect ip2ip = disabled
local peer = false
probe disabled,
Secure RTP: system (use the global setting)
mobility=0, snr=, snr_noan=, snr_delay=0, snr_timeout=0
snr calling-number local=disabled, snr ring-stop=disabled, snr answer-too-soon timer=0 rtcp_keepalive = system
voice class perm tag = `'
Time elapsed since last clearing of voice call statistics never
Connect Time = 218745, Charged Units = 0,
Successful Calls = 11, Failed Calls = 118, Incomplete Calls = 0
Accepted Calls = 42, Refused Calls = 14,
Bandwidth CAC Accepted Calls = 0, Bandwidth CAC Refused Calls = 0,
Last Disconnect Cause is "1 ",
Last Disconnect Text is "unassigned number (1)",
Last Setup Time = 60978145.
Last Disconnect Time = 59980727.
Matched: 90653927884 Digits: 1 Matched pattern: [9].. Preference: 0
Target: ipv4:192.168.4.3
TIB-SMR-CME-RTR#
