No ringback tone over SIP trunk
bokoo
Hello.
I have a DID/DOD connected to 3945 SIP(CUBE) and CUCM 8.0.
When I make a call from PSTN(Cell Phone) to our CUCM over SIP.
I don't hear any ringback, but the call is routed correctly and the call works fine once the called-party answers.
When I delete "progress_ind setup enable 3" at dial-peer 10, thne I can hear ringbacktone.
But that call was disconnect automatically after 20 sec while pickup that call from another phone in same pickup group.
RTP works fine during 20 sec before disconnect.
Attached file is a "debug ccsip mess" without "progress_ind alert enable 8"
I think CUBE receive BYE message from SP side with RESOURCE_UNAVAILABLE.
SP and we are just using G.711ulaw.
Any ideas are appreciated, thanks in advance!
voice service voip
allow-connections sip to sip
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
dial-peer voice 2 voip
destination-pattern .T
session protocol sipv2
session target ipv4:SP SIP Server
session transport udp
voice-class codec 1
voice-class sip asserted-id pai
voice-class sip early-offer forced
voice-class sip profiles 200
dtmf-relay rtp-nte
no vad
dial-peer voice 10 voip
destination-pattern XXXX
codec g711ulaw
session target ipv4:CUCM
dtmf-relay rtp-nte
I have looked at the Debug Output and here is the problem:
Firts of all - "progress_ind setup enable 3" applies only to H323 Signaling, it has nothing to do with SIP.
After, I have noticed that the Provider is sending SIP Earler Offer (INVITE with SDP) and also is waiting for 180/183 with SDP as well to get Early Media, but the CUCM does not send the RINGING message with SDP, but sends SDP only after the call has been answered in OK message, which is retried several times (sent OK message multiple times towards ITSP), which ignores SDP in OK message as it was expecting SDP in RINGING/Progress Message.
That's why you have RTP until the OK message with SDP is retryed. But as soon as Provider times out for SDP to be received 180/183 Messages (which does not happen) it disconnects the call.
So here is the solution: Ask Provider to use the Delay offer, but I think the ITSP will not do that.
Hope you understand the problem, and also could find other solutions as well.
You could try setting the CUCM SIP REL 1XX Options
Sip profile --->
SIP Rel1XX Options
This field configures SIP Rel1XX, which determines whether all SIP provisional responses (other than 100 Trying messages) get sent reliably to the remote SIP endpoint. Valid values follow:
Disabled—Disables SIP Rel1XX.
Send PRACK if 1XX contains SDP—Acknowledges a 1XX message with PRACK, only if the 1XX message contains SDP.
Send PRACK for all 1XX messages—Acknowledges all1XX messages with PRACK.
If you set the RSVP Over SIP field to E2E, you cannot choose Disabled.
Try setting to
Alex
Regards, Alex. Please rate useful posts.
